Where to get all suspension arms and bushes
Frazz82
Post by Frazz82 » Thu May 30, 2024 3:49 pm
I am going to be replacing all suspension bushes and arms front and rear shortly but I have had problems in the past with getting the wrong parts even when it says it will fit the c5 rs6.
Where's best to source all the arms and bushes I need.
Frazz82
Re: Where to get all suspension arms and bushes
Post by Frazz82 » Thu May 30, 2024 3:52 pm
https://034motorsport.co.uk/control-arm ... tgQAvD_BwE
Was looking at these for the front.
Nobbsy
Post by Nobbsy » Thu May 30, 2024 4:43 pm
Just replaced all the fronts on mine with these. Good OEM quality and fitted perfectly.
https://www.autodoc.co.uk/lemforder/1273462
Frazz82
Post by Frazz82 » Thu May 30, 2024 9:23 pm
Look ok them 👌.
I am struggling to find sets for the rear.
TOPMAN
Post by TOPMAN » Thu May 30, 2024 9:41 pm
Nobbsy wrote:Just replaced all the fronts on mine with these. Good OEM quality and fitted perfectly.
Good choice, this is the kit I’d go for if doing it again Image
srichards
Post by srichards » Fri May 31, 2024 8:52 am
I had the rears done and just had the originals powder coated and the bushes replaced. It was rather pricey. I think the arms were £800 each from Audi or some other ridiculous figure then and I don't think there were any rears on autodoc.
Has anyone got part codes for them?
There's a lot of stuff listed on autodoc now and some of the arms seem to do front and rear.
https://www.autodoc.co.uk/spares-search ... %5B%5D=273
Frazz82
Post by Frazz82 » Mon Jun 03, 2024 10:24 pm
Also keen to find out the part numbers if anyone can put thrm up.
bilko1
Post by bilko1 » Thu Jun 06, 2024 9:30 pm
Not sure if this is what you are looking for viewtopic.php?f=2&t=106104&hilit=meyle+ ... nsion+arms
Frazz82
Post by Frazz82 » Fri Jun 07, 2024 5:50 pm
Phoned Awesome GTI for a quote on some powerflex bushes comes in at nearly £1000. I have also emailed AutoDoc to see if they can price it up as there is loads of choices on the website and didnt want to get the wrong ones.
Felix2566
Post by Felix2566 » Sun Jun 09, 2024 12:17 pm
Be careful with the lemforder kits for the front. The lower arms supplied are not correct for the RS6. They are available from Autodoc, but need to be ordered separately.
What I bought from AD:
Front arm set 3553701 Lemforder
Lower arms 45958 Febi Bilstein (these are AD part numbers)
Make sure you confirm the part numbers are correct for yourself!
Felix2566
Post by Felix2566 » Sun Jun 09, 2024 12:20 pm
I use LLL Parts website for parts diagrams and numbers, have bought a few things off them in the past.
Audi tradition have a few things in stock for the RS6, but parts are thin on the ground for them
Frazz82
Post by Frazz82 » Mon Jun 10, 2024 12:32 pm
Just looked at LLL Parts looks good. It's what I was after for diagrams and part numbers so cheers mate 👍
Nobbsy
Post by Nobbsy » Mon Jun 10, 2024 4:37 pm
Out of interest, what was the issue with the Lemforder lower arms? Mine looked the same and fitted ok, since been 4 wheel aligned and all seems good.
Felix2566
Post by Felix2566 » Tue Jun 11, 2024 12:19 pm
From memory they are a tiny bit shorter (the non RS specific part number) , I'm sure I put them side by side and there was a noticeable difference.
But if yours has aligned up ok maybe its not true. The part number is different between the RS and the lower models, maybe it's the bush material rather than the physical dimensions
Felix2566
Post by Felix2566 » Tue Jun 11, 2024 3:18 pm
viewtopic.php?t=93727
Maybe I was talking rubbish....
