Gearbox recon..
Imola_Sid
Gearbox recon..
Post by Imola_Sid » Wed Dec 06, 2023 7:47 pm
Hello everyone,
I owned a C5 RS6 around 10 years ago! Looking for some current/up to date info.
My younger brother is looking to buy a C5 RS6 and suspects the gearbox is showing signs of giving up. He may be able to get it for a good price.
Who's best to go to these days for the gearbox and what can one expect to pay for a full recon?
Any help is much appreciated :thumbs:
Re: Gearbox recon..
Post by Shoppinit » Wed Dec 06, 2023 7:52 pm
Hey Sid! Good to hear from you. How’s things?
The latest info I have is in the FAQ. There was a place doing them site cheaply but I don’t really have any up to date info.
What’s the issue with the gearbox?
Imola_Sid
Re: Gearbox recon..
Post by Imola_Sid » Wed Dec 06, 2023 8:42 pm
Hi Ben,
All good here, thanks :thumbs: Hope all is well with you.
Just sold the C6 RS6 :( Gutted but a 3rd child meant it wasn't going to work for us. Replaced it with a 7 seater GL63, so not all doom and gloom.
Re the C5 - the 'PNRDS' all light up on startup and then goes normal shortly after. It's also thudding a little when driving hard in 'D'.
Have you got a link to the gearbox info in the FAQ's?
srichards
Re: Gearbox recon..
Post by srichards » Thu Dec 07, 2023 9:38 am
First thing to try is always a gearbox service and the F125 switch replacement. Check for other leaks as they seem to have them in later life. They also like to leak from seals just after a gearbox service so you have to do it again.
Re: Gearbox recon..
Post by Shoppinit » Thu Dec 07, 2023 10:08 am
End of the first post:
viewtopic.php?f=2&t=90358
Yeah, that sounds like a F125 issue. No biggy, although a PITA to replace (at least, I found it was).
Mine needs doing again. On a cold start, if I put it in D or R too quickly then it gives the PRNDS fault and thunks slams into gear. You've only got 4th or reverse when it faults out. I know it's the F125 though so I'm just trying to build up the courage to replace it again. I've got a cheap Chinese F125 to try, out of curiousity.
Anyway, what you describe doesn't sounds like the gearbox itself, but that doesn't mean that the gearbox isn't borked also. If you can drive it without the PRNDS lit up and it drives normally without slipping on WOT gear changes then I'd take that as a positive sign.
Imola_Sid
Re: Gearbox recon..
Post by Imola_Sid » Thu Dec 07, 2023 11:54 am
I think it changed gears ok when driven normally. It was when it was being driven hard that it thudded.
What codes would I expect to see on the Vagcom if it was the F125 sensor?
Imola_Sid
Re: Gearbox recon..
Post by Imola_Sid » Thu Dec 07, 2023 12:19 pm
Seller said he changed the 'range sensor' and cost him around £300. Assuming thats the F125?
Only place I spoke to who said they can do a full recon was QST but it's around £6,000!
Re: Gearbox recon..
Post by Shoppinit » Thu Dec 07, 2023 1:02 pm
Yeah, that sounds like a box at the end of its life.
Imola_Sid
Re: Gearbox recon..
Post by Imola_Sid » Thu Dec 07, 2023 1:41 pm
It's like nobody touches these boxes anymore. Maybe the parts are hard to find these days...
Re: Gearbox recon..
Post by Shoppinit » Thu Dec 07, 2023 1:57 pm
Somthing like this:
http://wiki.ross-tech.com/wiki/index.php/17090
Imola_Sid
Re: Gearbox recon..
Post by Imola_Sid » Thu Dec 07, 2023 7:05 pm
Thanks mate. I think he's going to pass on the car. Doesn't make sense taking a risk with £6k being the cost of a potential repair.
Re: Gearbox recon..
Post by Shoppinit » Thu Dec 07, 2023 7:40 pm
Yeah. Get an E92 M3. :)
Imola_Sid
Re: Gearbox recon..
Post by Imola_Sid » Fri Dec 08, 2023 6:13 pm
Had an E90 M3 myself. Was quite possibly the best all rounder I had. Not the fastest but in terms of a full package, performance, practicality, looks, reliability, cost etc it may just be the best car I've had. It literally did everything brilliantly and wasn't ridiculous money at the time.
Re: Gearbox recon..
Post by Shoppinit » Fri Dec 08, 2023 6:19 pm
They are fantastic. Might have to get one. I reckon they''ll be a future classic, too.
Imola_Sid
Re: Gearbox recon..
Post by Imola_Sid » Fri Dec 08, 2023 6:28 pm
Yeah, 100%. Not paid much attention to the coupe but the saloons have risen since I had mine. Mine had high miles (around 130k i think) but it was backed up with full BMW dealer history. I sold mine for around 13k in around 2019 iirc. Prices have crept up since then.
Users browsing this forum: asgor, srichards and 103 guests
