Steering angle sensor part
Hi Everyone, not sure if anyone can point me in the right direction, had ESP and ABS light on for a while no faults last year for mot but on the drive home lights came on so parked car up and long story short I connected VCDS up and only fault is Faulty steering angle sensor 00778 , so can’t find new part and found second hand part but local garage say best to fit new part but struggling to find new , so question is can I match part numbers with second hand part and fit without problems, garage say there are other numbers on the part are for software so are crucial hence they want to find new part Thanks in advance for any help.
Re: Steering angle sensor part
What is the exact fault you had, and what is the part number of the sensor you currently have?
Hi Mate,
1 Fault found 0778
Steering angle sensor (G85)
37-00 Faulty
My part number currently on the car - I J0 959 654M
1 Fault found 0778
37-00 Faulty
OK, that's the part number that I found. As far as I know, all the parts with the same part number are interchangeable. I found this on eBay:
https://www.ebay.co.uk/itm/204471201283
They accept returns so you could always nab it and return it if it doesn't work for you.
I would first remove your own unit and clean it out with compressed air. The angle sensor itself is pretty robust and it's unusual for it to break, but it can get gunked up or dirty. Ideally you'd strip it and clean the emitter and receiver inside, but I don't know how easily that particular model opens.
Before removing, make sure your wheels are dead straight. Then, when you remove the unit, mark the position of the ring with respect to the body, just in case.Once you've cleaned it, put it back in the same position, without having moved the steering wheel.
You'll almost certainly have to recalibrate it, but before that, check the reading it's giving and how it evolves when you turn the front wheels. You will want your car up on stands at the front for this or you'll stress your power steering. It should read 0.0 when the wheel is straight ahead.
If it seems OK, then calibrate the sensor. While the car is still in the air, turn the wheel from lock to lock to see if the fault occurs at a certain angle. You can do the same while watching the output from the sensor, too.
You can refer to this for the calibration:
http://wiki.ross-tech.com/wiki/index.ph ... Bosch_5.7)
Ok great, was definitely thinking about taking it of first and giving it a clean with air and as you say get the part as well .
Big thanks for advice and help mate .
Tricky times ahead as the 6 gets older and little or no parts available.
Took my kids to school the other day in the 6 and both of them had a wee smile getting in and missed the days it was out on the road most days now it’s once in a blue moon.
Anyway much appreciated.
Cheers Scott
Cheers Scott
Cool. Let us know how you get on or if you need any more info.
If you do end up using a new sensor, I'd be interested in doing an autopsy on the old one.
Ok no problem will do and of course you can have old one for your autopsy if I replace with new one .
I must get a sign made up for shopps workshop.
CSI UNIT
Autopsy division
CSI UNIT
Autopsy division
Who you calling a C UNIT?!
Users browsing this forum: Bing [Bot] and 127 guests
