Fuel pump upgrade
Sxcarmyboi
Fuel pump upgrade
Post by Sxcarmyboi » Sun Feb 05, 2023 2:19 pm
Well this morning I set about swapping my fuel pump set up over. Nice easy job to be fair.
Taking out the standard single pump and cradle to exchange it for a twin in tank pump set up. This new set up is capable of supporting 980bhp so plenty for once I have built my engine
C5 RS6 Avant
800+ BHP loading
1100+ ft lb loading
Re: Fuel pump upgrade
Post by Shoppinit » Sun Feb 05, 2023 2:22 pm
What about the main pump? Are you leaving that standard?
Sxcarmyboi
Post by Sxcarmyboi » Sun Feb 05, 2023 4:04 pm
The main pump is getting pulled out as not need with this setup
Will just fit a fuel filter in its place.
C5 RS6 Avant
800+ BHP loading
1100+ ft lb loading
Post by Shoppinit » Sun Feb 05, 2023 4:15 pm
Fair enough. Nice.
Lander91
Post by Lander91 » Mon Feb 06, 2023 5:37 am
Wow that's a serious wiring connector there! Race/mil spec looking.
Sxcarmyboi
Post by Sxcarmyboi » Wed Feb 08, 2023 12:00 pm
Oh yes nothing but the best with these parts
C5 RS6 Avant
800+ BHP loading
1100+ ft lb loading
V!per
Post by V!per » Wed Feb 08, 2023 7:26 pm
Mind Sharing some more details on the setup ??
Mɐʇʇ
Post by Mɐʇʇ » Thu Feb 09, 2023 10:19 am
RS Components sell lots of milspec connectors. I considered using some of them when I built my boat, but it was hard to justify the cost difference. Some of the 30 way ones I was looking at were mental money.
Sxcarmyboi
Post by Sxcarmyboi » Fri Feb 10, 2023 5:10 pm
You need to check out Rene rumler from Germany that’s where I purchased it from
C5 RS6 Avant
800+ BHP loading
1100+ ft lb loading
anditsoundslikebells
Post by anditsoundslikebells » Sat Feb 11, 2023 8:17 pm
Will Rene rebuild the motor?
Being in Holland, I have that idea in my head for some distant future.
RS6 C5 Avant 2002 Daytona Grey
TTH 620 - Wagner IC - OC.T 200cell&downpipes - DW400 pump - 034 TCU chip - FIS - B16 PSS9 - 034 control arms - H&R ARB - OZ Superturismo
Lander91
Post by Lander91 » Sat Feb 11, 2023 9:52 pm
Looks like he has a good solution for the pita maf setup. Too bad he's on the other side of the world for me :-(
Sxcarmyboi
Post by Sxcarmyboi » Sun Feb 12, 2023 9:11 am
He does do engine builds. Although he’s not building mine.
C5 RS6 Avant
800+ BHP loading
1100+ ft lb loading
Sxcarmyboi
Post by Sxcarmyboi » Sun Feb 12, 2023 9:12 am
I have got his 3” Maf too for my build
C5 RS6 Avant
800+ BHP loading
1100+ ft lb loading
Lander91
Post by Lander91 » Sun Feb 12, 2023 11:36 pm
Nice!
Sxcarmyboi
Post by Sxcarmyboi » Sun Feb 19, 2023 6:50 pm
Today I finished off my dual in-tank fuel pump set up. Running both the outlet hoses down to where the secondary fuel pump is/was housed. Then into a 3 way connection to a new bigger fuel filter then onto the standard under car fuel line.
Running this dual fuel pump setup means I no longer require the external fuel pump. So I have removed all this and replaced everything in that area with just one bigger fuel filter.
C5 RS6 Avant
800+ BHP loading
1100+ ft lb loading
Users browsing this forum: Google Adsense [Bot] and 55 guests
