Headliner removal - front dome light surround
Lander91
Post by Lander91 » Wed Apr 20, 2022 3:29 am
Hi team, I've got the headliner out without too much trouble. I'm at the last bit to tackle before I can get the actual fabric off. I've run into a roadblock in getting the surrounding frame for the front central dome light out. Seems like its 2 parts that have been fixed together during manufacture, and by fixed I mean plastic welded. See the pic for reference, you can see the little dots/tabs that are melted/fused in place. The 2 pieces of the frame, the backing Fram and the visible Fram/trim seen from below sandwich the headliner between them.
Anyone who's done the headliner job know if this can come out some how so I can properly re-glue the fabric, or does one simply stuff the fabric in the gap using a trim tool or sommit?
Frazz82
Re: Headliner removal - front dome light surround
Post by Frazz82 » Wed Apr 20, 2022 10:43 pm
I did mine 2 years ago. I just split in and glued it back together after new material was fitted.
Maybe another method but that way worked for me.
Lander91
Post by Lander91 » Thu Apr 21, 2022 12:04 am
Thanks frazz that's the conclusion I'm coming to as well.
Frazz82
Post by Frazz82 » Thu Apr 21, 2022 8:47 am
No worries.
I used a glue gun to put back together 2 years on and its still in place.
Gav66
Post by Gav66 » Fri Apr 22, 2022 11:47 am
Same here, cut off the plastic poles holding it together then glue gun to fix it back on easy job.
Users browsing this forum: Shoppinit, srichards and 81 guests
