Ditto...Quattrojan wrote: ↑Tue Mar 17, 2020 12:54 pmLinky Linky pleases8quattro1979rs wrote: ↑Thu Mar 12, 2020 5:47 pm£150 each side for the fronts, on a german website. i posted it in the general section a couple of days ago, oe quality zimmerman too.![]()
£1000 discs!?
Re: £1000 discs!?
Re: £1000 discs!?
Re: £1000 discs!?
those arent cross drilled?
Re: £1000 discs!?
Apparently those are prone to cracking. The drilled ones.... Although mine seem fine, although maybe somehow warped as I have judder. Not sure if that may have had anything to do will the drilled holes though.
And the grooved ones are apparently noisy.
Re: £1000 discs!?
Plain disks FTW.
Re: £1000 discs!?
Re: £1000 discs!?
No. I've got drilled because I run C6 disks and they don't do plain ones.
Re: £1000 discs!?
It's a faff. I wouldn't do it again.
If you want to take advantage of the bigger disk surface then you need calipers. You also need to bring the disks out 6mm IIRC. So they don't foul on the suspension arm. So that means you need a hub extension. It's a pain, basically.
Re: £1000 discs!?
Ah, couldn't remember if you had the special set up as well. Take it you just did some of the donkey work for the mongs?
Re: £1000 discs!?
Yup. Seems like a long time ago now. Might have provided some dimensions of stuff. Can't remember. I thought you had gone for some of the J-hook disks.
Re: £1000 discs!?
Nah, I've got the drilled "plus" discs. I couldn't justify the money them pair paid for their brakes at the time.
Re: £1000 discs!?
Could go with these cheaper than Audi and future replacements would be alot cheaper. https://www.ebay.co.uk/itm/Audi-RS6-C5- ... .l4275.c10
- s8quattro1979rs
Re: £1000 discs!?
Just for info, I managed to buy OE quality Zimmerman front discs (365mm) for £147 each side.
I checked lots of places (GSF/ECP/online) before ordering and these were the best I could find
Q-Parts24 GmbH & Co. KG on ebat Germany, but they can be ordered on the UK site too.
They arrived about 5-7 days after I ordered them.
Link to one side:
https://www.ebay.co.uk/itm/Bremsscheibe ... SwX6peIqVb
Link to one side:
Re: £1000 discs!?
I changed all for discs for Zimmerman.
I used winparts, very reasonable, good service, took a little time to get here, but worth it for the price. I used them for rear calipers as well.
Users browsing this forum: B_O_N_K, Google [Bot] and 72 guests
