I have recently purchased a 2004 Daytona Grey Avant and it has a misfire when cold. It clears up and runs smoothly when hot. The car runs perfectly once its warmed up, no misfire, no noises, no hesitation at all, very fast!
With my VCDS i ran a scan and it shows:
17981 - Left engine mount solenoid valve (N144) - P1573 - 04 - open circuit
17983 - Right engine mount solenoid valve (N145) - P1575 - 01 - short to plus
16684 - Randome/multiple misfire detected - P0300 - 08
17983 - Cylinder 6 - P0306 - 08 - misfire detected
A bit of history on the car, it has done 119k miles, but for the last 4 years it has only done 1000miles a year so it sat around alot, outside. It has still been regularly serviced annually despite the mileage, and recently had the cambelt, chains and tensioners done.
I started with the basics and swapped the coil packs around, cleared the faults but it stayed with Cylinder 6. I then swapped the spark plugs, cleared the faults and still showed up on Cylinder 6. As it has been sitting so much I wondered about bad fuel and a clogged injector, so I ran 2 tanks of Shell Vpower through it, but again same result. To eradicate an injector I swapped cylinder 1 and 6 injectors, but the misfire still comes back to cylinder 6.
This leads me to believe there is something wrong with cylinder 6 and not a bolt on component. I have just fitted 8 new spark plugs out of due course, but no change.
I run the misfire detection screens in measuring blocks 14 15 and 16 (I think it was...) and all misfires detected are in cylinder 6. On cold starts it runs into the 100's and all 7 others are at 0. Air flow meter measuring blocks appear to be matching quite well and these were both replaced in 2013 with genuine items. There are no misfires detected or shown once warm.
At some point there has been a mouse in the bay chewing on all the rubber boots of the plugs, but with it being temperature related it seems unlikely to be a loom fault? I do have Elsawin so with having a look at the wiring diagrams for a douple check.
Any help would be much appreciated, I'm hoping it's not the engine, but I do plan on running a compression test at the weekend.
And help or pointers would be much appreciated on what and where to check next.
Thanks in advance
