Anyone had this before?
DuncRS6
Post by DuncRS6 » Sun May 13, 2018 8:10 pm
Was walking around the car this afternoon and noticed a weird water streak coming from the back window trim. On closer inspection it looks like water has got behind the lacquer and it seems that the same is happening the other side but not as advanced. Oddly enough you can see it from one angle but not another. :(
Images below:
Had a quick search of the forum and couldn't find anything. Anyone had this before?
How much of a pain in the arse is taking the window trim off and can anyone recommend companies that may be able to fix this. Ideally want to get this fixed before it becomes a bigger problem.
benh999
Re: Anyone had this before?
Post by benh999 » Sun May 13, 2018 8:27 pm
Mine does exactly the same however it’s never an issue. I polished mine today and it comes straight off :thumbs:
daytonamart
Post by daytonamart » Sun May 13, 2018 8:29 pm
It almost looks like the start of a rust spot under the trim, hope I'm wrong.
Gone B7 RS4 Sprint Blue Avant
Gone B7 A4 Reflex Silver
Post by bam_bam » Sun May 13, 2018 8:30 pm
Yep. I've got that, on mine it causes a rust stain if I don't polish it (lighter coloured avus paint). It's worse on the near-side FWIW.
benh999
Post by benh999 » Sun May 13, 2018 8:33 pm
I’ve no idea how that trim comes off though?
Post by bam_bam » Sun May 13, 2018 8:36 pm
Just use an ultimate amount of force. It's what real men do, it never goes wrong.
benh999
Post by benh999 » Sun May 13, 2018 8:38 pm
:shock: :shock:
DuncRS6
Post by DuncRS6 » Sun May 13, 2018 8:52 pm
That is good to know.
Time to bust out the polish then.
DuncRS6
Post by DuncRS6 » Sun May 13, 2018 8:56 pm
That was the reason i got worried. Hopefully the above suggestions of polishing does the trick.
Post by Shoppinit » Sun May 13, 2018 9:08 pm
I would definitely be removing that trim to find out what's going on underneath. I suspect the polish is just removing residue of whatever is corroding underneath. If it can be corrected while it's still hidden under the trim then that's got to be a good thing.
Richard J
Post by Richard J » Sun May 13, 2018 11:20 pm
Mine does it too I just polish the stain off now and then. I assumed it was the steel clip which holds the trim on to the lip corroding, but I didn’t fancy removing the trim as it’s been the same since I bought it and got no worse. I can see the trim or clips breaking and not going back on properly.
Ajc
Post by Ajc » Mon May 14, 2018 6:25 am
It's the clip for the window trim that's rusty and leaking it's rust p**s down the quarter . I replaced my clips when I painted the car . However 2 years on and it's just starting too do it again .
Cheers Al
DuncRS6
Post by DuncRS6 » Mon May 14, 2018 8:18 am
I replaced my clips when I painted the car...
Was it fairly easy to remove the trim?
...I can see the trim or clips breaking and not going back on properly.
The way my luck is going this year I'll will probably manage to get the clips and trim off without a problem then the car will spontaneously combust on the drive. Leaving me nothing but a smouldering pile of ash and some window trim.
Post by chunky79 » Mon May 14, 2018 10:22 am
Problem then solved though, no?
DuncRS6
Post by DuncRS6 » Mon May 14, 2018 10:35 am
Very true!
Users browsing this forum: Google Adsense [Bot], rs4wagon and 78 guests
