Couple of hard to trace faults
JonRS246plus
Post by JonRS246plus » Sat Jan 27, 2018 1:25 pm
I have a couple of faults with the car (RS6 Plus 2004):
1. Brake light warning comes on sporadically. TTS Roadsport couldnt trace it to anything....the battery however is on it way out - is this connected do you think as it only comes on on start up....low voltage triggering it?
2. Adaptive headlight - again, sporadic..... fault codes:
- 00774- Level Control System Sensor: Rear Left (G76) 28-10 - Short to Plus - intermittent
- 00776 - Level Control System Sensor: Front Left (G78) 28-00 - Short to Plus
They "appeared ok" and we ran out of time to address it - any thoughts appreciated as to (a) what the faults could be and (b) are they capable of being done by a reasonable competent person?
Jonathan
Ajc
Re: Couple of hard to trace faults
Post by Ajc » Sat Jan 27, 2018 2:18 pm
For the battery , might be worth checking the condition of the mega fuse under the scuttle . Make sure that it's not corroded and that it's clean . They are a common fault for alsorts of gremlins.
Headlamps I'm not too sure about but there is a potentiometer on one of the lower arms , May be worth Checking that with a meter and the wiring too it.
Shopp Is well versed in that field and may shed more light on the subject ( excuse the pun).
Cheers Al
Post by Shoppinit » Sat Jan 27, 2018 2:21 pm
1. Did you check the brake fluid?
2. I'm just getting a new Elsa. The one I've got has half the electrical diagrams missing. Sounds like an easy fix, though.
Ajc
Post by Ajc » Sat Jan 27, 2018 2:30 pm
For some reason I misread that as battery warning light :knob:
Cheers Al
Users browsing this forum: Majestic-12 [Bot] and 58 guests
