RS6 Plus C5 misfiring and misbehaving
Re: RS6 Plus C5 misfiring and misbehaving
Agreed. I'm a bit rusty on it all, but I think load index of 170 indicates Stage 1 remap.
And there is no magic/rescue button I guess.. The one that would bring everything to stock...
Well, actually, there is a way - I've done it.
After my major rebuild:
Roughly, assume your map is locked for reading (if non stock, then most likely is), then you need a piece of software called galletto and a lead to match it.
You then pull the ecu from the car and power it up on the bench while jumping a couple of pins - this puts it in boot mode, so you can backup the existing tune.
Then you can pop it back in the car and apply any tune you want using the nefmoto software - stock copies of the map are on the nefmoto site, too.
- I backed up the stage 1 tune,
- reverted to stock to check everything was good
- Coded out the SAI
- Then modified and reloaded the stage 1 tune to remove SAI as well
i had similar issues and it turned out it was one of the spark plugs and a coil, also carefully inspect the coils harness, they tend to crack at this age and you'll get a short to ground which doesn't comes up on VCDS...
2004 RS6 by ABT, madly in love with it, RNS-E, ST coilovers, new TC, 19x9x29 RS4 B7 wheels, non-resonated Milltek w/blk tips, TBC....SOLD - but never to be forgotten!
2004 RS6 ebony schwarz, SE exhaust, 19'' rims - SOLD
'09 RS6 C6 - the great white - now, this means business!
If there's an issue with one psark plug and/or one ignition coil, the computer would show you that this cylinder misfired, wouldn't it?..mik15 wrote:i had similar issues and it turned out it was one of the spark plugs and a coil, also carefully inspect the coils harness, they tend to crack at this age and you'll get a short to ground which doesn't comes up on vcds...
But mine shows random misfire...
It's not very good at detecting exactly which cylinder is misfiring.
