Fuel pump options A6 - S6 - RS6
Re: Fuel pump options A6 - S6 - RS6
Just as a side note , Mine had a misfire under boost shortly before one of my turbos sh*t it's self . You say you've checked the requested and actual boost ? .
Cheers Al
Going for a test-ride now.
will come back with test results.
These? ready to change them all.. ))
Diverter Valves?Ajc wrote:Fuel pressure regulator, N75 , Diverter Valves. ? All reasonably priced and worth changing I would suggest.
Also worth checking your injector spray patterns
No the recirculating dump valves. They are plumbed in too the charge carrier with vac pipes going too them . Marked as DV's on your pic .
Cheers Al
If you suspect fuel starvation then you should log your lambda values while driving and see what happens when the problem occurs.
Also, as already said, log the requested and achieved boost.
Aren't there any DTCs stored?
