18" Alloys
18" Alloys
Nooby question inbound, Looking at getting these for my winter setup (yes, it is a little early to worry about that)
http://www.ebay.co.uk/itm/AUDI-A3-A4-GE ... 2428604867?
Are they correct fittement (seen alloys with 5x100 and 5x112. Like these http://www.ebay.co.uk/itm/112012083931? ... EBIDX%3AIT)
if the are the right fitment do they just bolt on, or would they need spigot rings? (Not too hot on VAG fitments)
Re: 18" Alloys
You need 5 x 112 but you also need the right offset. That depends on the width.
Re: 18" Alloys
Keep an eye out for b5 rs4 wheels (hard type) et20 so sit a tad further out but look good! Or you often see a5 wheels come up cheap in 18's and are normally et20/30 but you will need a spigot to take them down to size.
Re: 18" Alloys
Thanks for the help. Problem with only dealing with Fords/FWD's didn't have to worry about ET's. Glad you guys pointed that out.
Should i try to keep to 7.5j-8j to prevent them rubbing the arches?
I'll keep looking for those ones then. If Push came to shove, i could get any set and run spacers, to push it out to ET 20-30
Re: 18" Alloys
Yeah, but then you could potentially be spending lots on bolts and spacers. You might as well try and get a set of genuine 18 or 19 inch alloys. Or even some replicas with the correct offset.
Re: 18" Alloys
That's true, found these ones, seem reasonable?
http://www.ebay.co.uk/itm/Genuine-Audi- ... 2065899152
Re: 18" Alloys
Don't know what the ET is. Are they B5 alloys? Isn't that when Audi was making them out of butter?
Re: 18" Alloys
Why don't you see if site Sponsor revolution has any good deals. Not sure if they do a discount code. These would look fine on the RS6:
http://www.revolution247.com/catalogue/ ... d-cut-face
Re: 18" Alloys
Or maybe try and find some genuine B7 RS4 wheels. I think they look great on the RS6, even if it disturbs me a bit mixing and matching models / generations.
Re: 18" Alloys
If you do decide to go for b5 wheels make sure they are the hard type, just ask for the serial numbers. I think I paid 300 for my b5 rs4 rims (hard type) so the price seems good if they are the right ones.DirtyDiesel wrote:That's true, found these ones, seem reasonable?
Re: 18" Alloys
And the b5 wheels are et20
Soft wheel part number : 8DO 601 O25T
Hard type part no. 8DO 601 O25AE
Re: 18" Alloys
Just remembered what you mean by the soft and hard ones, forgot about the butter ones. Those ones are the genuine B5's but they are in fact the soft ones (Can see 025T)
I'll have a revolutions if they're a decent price. I take it they aren't going to fall apart like cheap alloys?
Users browsing this forum: Majestic-12 [Bot] and 62 guests
