Transmission fluid drip
- 1st Gear
Re: Transmission fluid drip
Yes. That seems to be the point where it's leaking. Are there any other seals in that area that are known to fail?
2003 RS6 Avant, Daytona grey
2012 Toyota GT86
2014 Toyota Prius Plus 7
2012 Toyota GT86
The main culprit is the transfer box seal, but it sounds like your front diff seal is leaking. It's not a usual place for a leak, but the bearings can wear so you're probably better off replacing both the seal and the bearing. At least check for play.
According to the workshop manual you can get the diff flange off with the engine and box in the car - whether left or right - but I've got a niggling memory that only one side can come off easily.
- 1st Gear
It "looks" easy enough to get the driveshaft out of the box on the left side. I'll remove the suspension on that side anyway since I'm doing the suspension at the same time. I'll check the bearings too.
2012 Toyota GT86
2012 Toyota GT86
Yeah, it does look easy enough. Famous last words!
I would want definite confirmation of the exact location of the leak before ripping things apart.
- 1st Gear
Indeed. I'll be doing other work with the car on jacks this weekend. I'll clean everything properly and see if I can spot the leak before tearing into things.
2012 Toyota GT86
2012 Toyota GT86
