So, yesterday took the car out for a good long run - and the a/c is still mostly forced off (ECON mode). During some stop/start traffic noticed for the first time ever, that the coolant needle moved (up) from the usual static 90 deg. Didn't continue to rise - just stayed at roughly 95 deg.Dxthomas wrote:Issue #1
White smoke noticeable from both exhausts. Doesn't appear to create more smoke on revving - infact, is more noticeable on start-up and tick-over. I don't remember the car having always done it - noticed it 3 or 4 months ago. Some symptoms / indicators which may help diagnose:
- Rich smell from exhaust
- exhaust tips look more sooty than i would have expected - albeit this may just be normal?
- the coolant warning light came on for the first time last week, requiring 1l of top-up
- At the same time as the coolant warning light, the a/c intermittently won't budge off ECON mode - blowing warm air through the vents
- the external ambient temperature guage has been pretty bonkers since I purchased the car - often reading 5-10 degrees warmer than it actually is
- car runs and drives perfectly. No start-up problems
Have come back from a run this morning where the needle stayed at 90 deg. but the a/c is still on ECON. Noticed that the fan is running a fair bit (working hard). Just done the diagnostics trick via. the a/c unit - and had a coolant temp. reading of 95 deg. which; whilst sat idling for 5 mins - rose to 99 deg. The needle on the dash gauge didn't budge off 90 deg.
The car is booked in to my local garage next weekend. Appreciate any thoughts beforehand. Reading up on this forum - maybe coolant temperature sensor / sender?
