fuel gauge back on zero
this isn't the first time its happened.
I was on empty and no v power local so I put some 98 in but only £25( wot with it not being the highest octane or cheapest fuel).
drove home and parked up
gauge reading almost top of the red. got in this morning and it was reading empty again. wtf
I know these like to drink a lot of fuel but this has got me thinking I'm leaking fuel/or the gauge has died.
Re: fuel gauge back on zero
I think they're all a bit iffy when you get down below a third of a tank. Mine intermittently says it's empty in the morning and then usually will come back up on the drive to work. If it doesn't I fill up just to be safe. (Although last time I put 83.5L in
oops)
Standard C5 fuel gauge.
Does your fuel gauge indicate full when the tank has been filled? The reason i ask is when i bought mine it always settled slightly below the full tank indication, using VCDS i re-calibrated the gauge to indicate full when the tank was full, this in turn gives better accuracy when reading low levels, it doesn't seem to suddenly indicate empty when been left over night with less than a 1/4 tank showing.
- 1st Gear
Mine does this , I'll park it in the garage with a quarter of a tank , come back to it a week later and empty lol
Sounds familiarChrisniss91 wrote:Mine does this , I'll park it in the garage with a quarter of a tank , come back to it a week later and empty lol
RS6 C5, MTM
Mine does exactly the same park it up at a quarter or less next morning fuckall
Had this many times its the car laughing in your face at putting in such a low amount of fuel shame on you!
KV53 YML - RS6 Avant - Stolen Hampshire
RS 51X CS - RS6 Avant - Sold
Lol'd.
This is actually a normal occurrence and it's down to the split fuel tank on the c5. There is a pump that pumps the fuel from side to side and two senders that work the fuel level out from both sides.
So it divvies the fuel out between both sides and such a small amount won't float both senders.
S4 b5 340bhp
Rs4 b5 507bhp
Rs6 c6 project 800bhp
S3 stock daily work hack
Rs4 b5 507bhp
Good to know, I can get back to the other problems that need sorting.
Does the computer readout have the same problem?
I've finally got my head together but now my body is falling apart!
Users browsing this forum: No registered users and 154 guests
