diff ratios
diff ratios
hi all, recently bought an rs6 avant 2004 and love it. however the pinion bearing in my rear has taken a turn for the worse. i picked up a second hand diff yesterday, went to fit today but i have different ratios. anyone know if there are different ratios fitted to the rs6. i have a 3.2 in my car and was supplied a 4.1 as an rs6 diff.
thanks in advance
thanks in advance
Re: diff ratios
FON
You should have a 3 letter code stamped on the diff housing. There are 4 different codes with 2 different ratios. Which one(s) have you got?
Re: diff ratios
what is this FON??
is it the code on the alloy part of the bottom of the diff, if so both have the code but different ratios.
Re: diff ratios
both have jkp stamped on them
Re: diff ratios
Should be 3 letters followed by 5 numbers.
Re: diff ratios
thanks, have you got the codes and relevant ratios to hand? done endless searching but not come up with anything.
Re: diff ratios
DSA xxxxx : 37:9 -> 4.111
EUS xxxxx : 37:9 -> 4.111
DUR xxxxx : 37:10 -> 3.700
EUU xxxxx : 37:10 -> 3.700
What happened to the hotlink on FON?
FON
FON
Re: diff ratios
thanks I'll have a look for the code, strange that mine measures as a 3.2:1 though.
Re: diff ratios
Ok so the only code I can find is ggw followed by 6 numbers. On both diffs. Some googling seems to suggest this is 3.19 ratio which is what I have.
Anyone know about this code?
Re: diff ratios
Mmm. Found some more info. GGW is the final drive code for the RS6. Looks like it was only fitted to the RS6. The ratio is 37:9.
Re: diff ratios
I can't find any 3.2 diffs on the RS6 era quattro cars. Where are you getting that from?
Re: diff ratios
Ok, I'm going to pull the bottoms of both tomoz so I can count the teeth to see what's going on for sure. Thanks for all the help.
Re: diff ratios
So took the diff out last night and stripped it, thankfully had 37/9 ratio, pinion bearing was really seized so getting the wrong reading when working it out from spinning pinion x times to 1 rev of output. New diff in and all good!
Nice one for the help, much appreciated
Users browsing this forum: allroadadi and 58 guests
