VCDS Codes Advice please!!
Re: VCDS Codes Advice please!!
Sunday,22,November,2015,16:53:33:62939
VCDS Version: Release 12.12.0 (x64)
Address 01: Engine Labels: 077-907-558-BCY.lbl
Control Module Part Number: 4D1 907 558
Component and/or Version: 4.2l V8/5VT G 0002
Software Coding: 0010752
Work Shop Code: WSC 02195 785 00200
VCID: EBD5A127C970AB46D11-5000
6 Faults Found:
16985 - Internal Control Module
P0601 - 001 - Memory Check Sum Error
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - Intermittent
16686 - Cylinder 2
P0302 - 001 - Misfire Detected - Intermittent
18393 - Coolant Control Module 2 (J671)
P1985 - 002 - Malfunction - Intermittent
18308 - Coolant Fan Control 2
P1900 - 004 - Open or Short to Ground - Intermittent
18010 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Readiness: 0000 0001
6 Faults Found:
16686 - Cylinder 2
RS6 C5 05 plate very tidy.
Past.... Only have 500 characters ! RR Sport X 2 Nice but boring RS6 C5 03 Sold due to losing 25K of value in 12 months of ownership !
Still have a 72 GT6 and a few Big Bikes....
Mmm, misfire cylinder 2, too rich bank 1... Maybe you've got a leaky injector. Or a faulty coil pack or plug not igniting the fuel.
I would check for boost leaks first, then maybe swap the MAFs bank 1 to 2 (though I don't think this is MAF related).
Then I would swap the bank 1 injectors with the bank 2 injectors.
Then the bank 1 coil packs with the bank 2.
Arghhhh
All cleared down after battery disconnect and below is all that came back which are unrelated to the issue.
Going like a rocket ship with no flashing dash issues and no codes.
Business as usual I guess until lumpy tick over and low rev problems!
Sunday,22,November,2015,17:07:45:62939
Address 01: Engine Labels: 077-907-558-BCY.LBL
3 Faults Found:
Readiness: 0010 1001
3 Faults Found:
Fan issue should be easy enough to fix. Did you check the fuses yet?
No I didn't as Rugby, Tv and beer dragged me away!
Everything Swapped from Bank one to Bank two.
Lets see what happens now. I checked the fuses in behind and all ok. Haven't checked the normal ones yet. I believe I can spin up the fans in VCDS.
I don't think its a boost leak as its lumpy at tickover. I will know tomorrow if its a coil/maf or plug. I hope. If Cly 6 plays up its a coil. If 2 plays up its a plug.
*looks up* Eh? What's going on in here?Shoppinit wrote:You might have a hole in a boost pipe which is opening up under load, a bit like a sphincter (bam looks up expectantly), which is causing over-fuelling.
Resurected from the dead post....
It was just a single coil on Cylinder 2. When I swapped it from one side to the other everything worked for 3 weeks and then Cylinder 6 started throwing up errors!!
New coil from GSF and it works but shows an excuse fault!! Genuine previously enjoyed one on its way.
I better look at the Cooling fan and module thing now. Can't see any fuses blown even the big one in the back. I guess it's go to the module and see if it's getting any power.
Where in VCDS can you power a fan to see if it works?
Output tests.
Users browsing this forum: Majestic-12 [Bot] and 83 guests
