Topping up rear output shaft oil.
mavada
Re: Topping up rear output shaft oil.
Post by mavada » Fri Nov 28, 2014 2:07 pm
Passed MOT. :D
But when loosen the plug to fill the rear shaft stuff oil up, the oil came out massively. Didnt understand that.
How is it possible to overfill it? or does the oil expand that much? (or did we loose the wrong plug...?)
Think it was around 300-500ml that came out and burnt the mechs hand...
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Post by Shoppinit » Fri Nov 28, 2014 2:10 pm
:shock:
Which plug did you undo? Show us on ETKA.
mavada
Post by mavada » Fri Nov 28, 2014 9:02 pm
I think its nr 44, the one in an angle circled in red...it is in the cat area...
Yellow Koni's
Post by Shoppinit » Fri Nov 28, 2014 9:40 pm
It looks like the right one.
I'm thinking that the oil seal from the box to the transfer box has failed letting ATF into it.
mavada
Post by mavada » Fri Nov 28, 2014 9:45 pm
...never heard of that before.
Is it possible its filled from the axle hole?
Yellow Koni's
bakustax
Post by bakustax » Fri Nov 28, 2014 10:14 pm
mavada wrote: Is it possible its filled from the axle hole?
Only a Dutchman could say that with a straight face... :bigwave:
mavada
Post by mavada » Fri Nov 28, 2014 10:25 pm
is it possible the oil expands when hot enough to drip out the filling hole?
Did you guys top it up when box was cold?
Yellow Koni's
Post by Shoppinit » Fri Nov 28, 2014 10:33 pm
Lol at axle hole.
Yeah, but not that much. A dribble maybe.
You need to do the level and see if it does it again in a while.
You might wanna check the ATF level, too.
mavada
Post by mavada » Fri Nov 28, 2014 10:45 pm
Which number is that for checking atf in the etka drawing?
Yellow Koni's
Post by Shoppinit » Fri Nov 28, 2014 10:51 pm
It's not on that drawing. It's on the sump pan.
mavada
Post by mavada » Fri Nov 28, 2014 11:21 pm
yeah i should have known that.
Thats another job to add to the winter to do list...
Thanks. :thumbs:
Yellow Koni's
mavada
Post by mavada » Sat Nov 29, 2014 11:33 am
I just remember i wasnt present when they performed the seal replacement. Normally im always present, but they couldnt tell me when they started with it that day...
Wouldnt surprise me all their ramps were in use (the second time car was in for it, first time all the oil came out on my garage floor) so they just jacked it up on the right side of the car and filled it...
Yellow Koni's
Post by Shoppinit » Sat Nov 29, 2014 11:42 am
That would be extremely unprofessional.
mavada
Post by mavada » Sat Nov 29, 2014 12:33 pm
...ive seen bigger unprofessional stuff in the past unfortunately. :thumbsdown:
Thats why im always present when theyre working on my car.
Nowadays im doing most of the stuff myself, so its me to blame when i fck something up, and save some cash to...
Yellow Koni's
mavada
Post by mavada » Sat Nov 29, 2014 1:17 pm
Still need a proper ramp to get under the car...
https://www.youtube.com/watch?v=NgVUZJA17oY
Yellow Koni's
Users browsing this forum: 111marc111, Bing [Bot] and 83 guests
