What's this fault?
Whitey33
What's this fault?
Post by Whitey33 » Sun Oct 12, 2014 8:40 pm
Is any one familiar with this fault please
mavada
Re: What's this fault?
Post by mavada » Sun Oct 12, 2014 9:07 pm
16825/P0441/001089 - EVAP Emission Control Sys: Incorrect Flow
Possible Symptoms
Malfunction Indicator Light (MIL) active
Possible Causes
Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) faulty/jammed
Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) faulty/jammed
Evaporative Emission (EVAP) Canister Sealing faulty
Pipes between Tank Breathing and Throttle Body leaky/blocked
Possible Solutions
Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
Perform Output Test
Check Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115)
Perform Basic Setting
Check Pipes between Tank Breathing and Throttle Body
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Whitey33
Post by Whitey33 » Sun Oct 12, 2014 9:28 pm
Brill, thanks for that.
