What's this fault?
What's this fault?
Is any one familiar with this fault please
Re: What's this fault?
16825/P0441/001089 - EVAP Emission Control Sys: Incorrect Flow
Possible Symptoms
Malfunction Indicator Light (MIL) active
Possible Causes
Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) faulty/jammed
Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) faulty/jammed
Evaporative Emission (EVAP) Canister Sealing faulty
Pipes between Tank Breathing and Throttle Body leaky/blocked
Possible Solutions
Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
Perform Output Test
Check Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115)
Perform Basic Setting
Check Pipes between Tank Breathing and Throttle Body
Possible Symptoms
Possible Causes
Possible Solutions
Perform Output Test
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Yellow Koni's
Brill, thanks for that.
