2003 RS6 Tool what's missing?
hello,
Just got the wheels back from a refurb and noticed the tool for removing the plastic wheel nut covers is missing. What else is missing
attached a picture of the tool kit and car, not cleaned properly but going well.
lapman
lapman
Re: 2003 RS6 Tool what's missing?
Your missing the electric air pump and screw driver by the looks of it.
That's a start then,
lapman
lapman
If you're going to be picky, you best check the date on your tyre goo. It'll most likely be out-dated.
Then throw it away and replace with a chocolate teapot, it'll be about as much use.bam_bam wrote:If you're going to be picky, you best check the date on your tyre goo. It'll most likely be out-dated.
If the tyre goo is a load of poo, what do people recommend using? I shall be heading down to the Alps in a few weeks so want to be prepared in case I get a puncture.
RS6 C5, MTM
A spare tyre on a rim if you can get one in! I gad a puncture in my C6 in the middle of France on a Friday afternoon. Ball ache.
I think there's supposed to be a little spanner in there too. I'll check mine later.
You got your locking wheel nut key?
Daytona RS6 Avant
Spanner is a 10/13mm one. God knows what you need it for though.
Daytona RS6 Avant
Yeah, you're right, I think there was a little spanner. His locking key is present though.
I haven't seen one of these for a while, I've not lifted the boot cover in the 'loon for a very long time. The avant just has a dirty big 7.5L meth tank where the tool set used to be.
950 nm torque!
Ohh running bridgestones because they are the best
yep 03/2007 well past it's best....bam_bam wrote:If you're going to be picky, you best check the date on your tyre goo. It'll most likely be out-dated.
I had a look for a chocolate teapot as well, going to Halfords to pick one up.
There is also a back plastic thing with a thread at one end and a small at the other. Any idea what that is for?
lapman
Halfrauds has gots loads of things just as useless as chocolate teapots. Glass drum kits on special offer, too.
lapman
950 nm torque!
Users browsing this forum: 111marc111, Google Adsense [Bot], srichards, steve2003rs6 and 49 guests
