Fault code
RS6Mule
Fault code
Post by RS6Mule » Tue Sep 03, 2013 8:00 pm
Bank 1 and Bank 2 secondary airflow insufficient flow ? Management light on. Anyone seen this ?
Re: Fault code
Post by Shoppinit » Tue Sep 03, 2013 8:16 pm
Yes. Fcuk loads of people have seen it. Chunk, where are you with your "Search mofo" comments?
It's a problem with your secondary air injection. It'll be either perished vac pipes, broken recombiner valves or a dodgy pump, possibly a clogged filter. Nothing terribly serious.
RS6Mule
Re: Fault code
Post by RS6Mule » Tue Sep 03, 2013 8:24 pm
Sweet !! I've had her 2 month now and this is the first "fault" (excluding GPS antenna) cleared the code so ill wait and see the outcome before getting the Ovies on and spanners out ! Think she's still on the original box as well at 132K !!
the6
Re: Fault code
Post by the6 » Tue Sep 03, 2013 8:53 pm
RS6Mule wrote:Sweet Think she's still on the original box as well at 132K !!
Well that will go one of two ways, either a "lucky you" :thumbs: Or a "unlucky you".... as its about time! :thumbsdown:
RS6Mule
Re: Fault code
Post by RS6Mule » Tue Sep 03, 2013 9:17 pm
It'll be fine !!
Russellj80
Re: Fault code
Post by Russellj80 » Mon Sep 09, 2013 2:08 pm
Check your air box is positioned correctly. You've not had it off lately have you?
Re: Fault code
Post by Shoppinit » Mon Sep 09, 2013 3:22 pm
Russellj80 wrote:You've not had it off lately have you?
*snigger*
Russellj80
Re: Fault code
Post by Russellj80 » Mon Sep 09, 2013 3:30 pm
Snigger all u want Shop it can cause major grief!
Russellj80
Re: Fault code
Post by Russellj80 » Mon Sep 09, 2013 3:36 pm
.... Not getting it off!! :p
Users browsing this forum: Majestic-12 [Bot], rs4wagon, srichards and 122 guests
