Air-con problem
Re: Air-con problem
Ive got the same problem.been upto the garage and the high pressure switch isnt working.Use him all the time and he said the bumper needs to come off,researched on here and its saved me £££££££££
Re: Air-con problem
I've just been told that you need to initialise
The system which is why the bumper needs to come off,is this the case?
Re: Air-con problem
Re: Air-con problem
Does that mean its bollocks?
Re: Air-con problem
It certainly sounds like bollocks to me. Doesn't make any sense. Just had a look at the procedure for G65 - makes no mention of "initialising the system". Just whip the switch out, whip a new one in and bob's your uncle.
Re: Air-con problem
Depends on if the air con system seals when the switch is removed (very much doubt it) , if not then best of luck. The air con gas is not good for you or anyone else!! Best thing to do is drain the system, change the switch then re-gas. You have to be registered to handle air con gas aswell, me is registered.
Just a note, you can be prosecuted for releasing air con gas onto the atmosphere.
Re: Air-con problem
My understanding is that it self-seals when you remove the switch.
I admit, it's a bit ambiguous, though. Maybe someone who has done it can chime in?Manual wrote:The refrigerant circuit remains closed - connection with valve.
Re: Air-con problem
So i changed the pressure valve yesterday,simply screws off,no gas leak,screw the new one in,plugged the cable back in,job done all working.could'nt believe my mechanic wanted to charge me 5 hours labour to do the job.he has just lost a regular customer
Re: Air-con problem
That's shocking! Even to remove & replace the bumper it's only an hour... taking your time.
- Russellj80
Re: Air-con problem
These mechanics will always try to baffle you in order to line their own pockets. There is no gas leak because there is some kind of schrader/pesto valve inside the switch. As soon as you unscrew it the system remains fully sealed!
Re: Air-con problem
Mmm. Pesto.
- Mr Footlong
Re: Air-con problem
Pesto makes me gag
Current:
Gone:
Gone:
Re: Air-con problem
I didn't know that, good to know! (about it self sealing that is)
Users browsing this forum: Google [Bot] and 82 guests
