ATF changed
ATF changed
Took my RS6 in for an ATF change today. The reason for this was there was a slight weep from the gearbox sump gasket. Audi had fitted a new box in 2009, and car has only done 9k ish since. The sump bolts were loose and a chunk of the gasket was missing. Took some photos to email to Audi so I can cus them. I had the filter changed as well as the fluid and a new gasket. Anyways, I have a question. The gearbox took 6.5 litres of fluid after a drain and refill, does this seem right? Part were from TPS, cost £162.00 at trade price.
Re: ATF changed
Shocking.
6.5 liters sounds spot on for an in-situ ATF and filter service.
