Bonnet Venting
adsgreen
Re: Bonnet Venting
Post by adsgreen » Sun Mar 24, 2013 2:35 pm
Wonder if its worth removing the rear under bonnet rubber weatherstrip so heat gets drawn out and over the windscreen.
Re: Bonnet Venting
Post by Shoppinit » Sun Mar 24, 2013 2:57 pm
Not a bad idea that.
mavada
Re: Bonnet Venting
Post by mavada » Sun Mar 24, 2013 3:08 pm
adsgreen wrote:Wonder if its worth removing the rear under bonnet rubber weatherstrip so heat gets drawn out and over the windscreen.
...prob all under bonnet weatherstrips...
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Re: Bonnet Venting
Post by chunky79 » Sun Mar 24, 2013 4:02 pm
R8GXR wrote:Well heres mine, all nicely stamped out, just needs sanding and paint. :boots:
I guess the V8 was deliberate? 8 slots below the V.
R8GXR
Re: Bonnet Venting
Post by R8GXR » Sun Mar 24, 2013 7:43 pm
Actually no...... But well spotted. For everyone else, yes I had the V and 8 slots to replicat V8. :biggrin3:
mavada
Re: Bonnet Venting
Post by mavada » Tue Apr 09, 2013 7:17 am
For the ones interested...
RS6 Hood Vent Templetes.pdf
(1.17 MiB) Downloaded 93 times
Yellow Koni's
jordan
Re: Bonnet Venting
Post by jordan » Fri Apr 12, 2013 11:08 am
It's a common misconception that air flows OUT at the back of a bonnet. Hence why you don't see race cars with the back end lifted up essex style.
There is normally a HIGH PRESSURE area at the bottom of the windscreen causing air to flow INTO the bay which is why the cabin air intake is always there.
Blue is low pressure red is hIgh pressure. The pic is not RS6 specific but generaly speaking vents in the center of the bonnet work better than vents at the rear of it.
C5 S6 4.2ltr V8, black, muffler-ectomy, RNS-E + bluetooth, 20" B7 rs4 style alloys, more to come.........
mavada
Re: Bonnet Venting
Post by mavada » Fri Apr 12, 2013 11:33 am
all in all, the Sportec vent mod is by far the most easy/cheap mod you can do really, the amount of heat going through it is huge (heard of one wanting to know if it really works: he couldnt hold his hand more then 30 seconds cos of the air coming out, and thats while at a standstill, let alone while driving and more air gets drawn out of the engine bay.
What keeps me from doing it is the risk of dirt/animals going in...
Yellow Koni's
Re: Bonnet Venting
Post by chunky79 » Fri Apr 12, 2013 11:56 am
You mean like a bear or whale mav?
mavada
Re: Bonnet Venting
Post by mavada » Fri Apr 12, 2013 12:00 pm
Yellow Koni's
Re: Bonnet Venting
Post by chunky79 » Fri Apr 12, 2013 12:14 pm
That there would have my size 11, fecking hate cats!
adsgreen
Re: Bonnet Venting
Post by adsgreen » Fri Apr 12, 2013 1:10 pm
I'd nevered considered that.
I guess I always thought the airflow over the windscreen would be less compressed but those pics say otherwise.
So the air is hitting the windscreen and instead of immediately flowing over is just sitting there getting higher pressure before it goes...
mavada
Re: Bonnet Venting
Post by mavada » Mon Aug 18, 2014 11:12 am
Yellow Koni's
