Worrying experience...
chrisn6
Post by chrisn6 » Sun Sep 30, 2012 6:29 pm
Hi boys & girls,
On returning to my car today after parking it on a very slight upward incline (5 degrees?) the engine turned over without a hint of trying to fire. I tried maybe 7 or 8 times with a few lengthy attempts. The car had never failed to fire within a few seconds over the 20 months ownership. I called for breakdown assistance and after five minutes, decided to try again. It fired up immediately! I cancelled the recovery and drove home. Started perfectly a few hours later also. I hate intermittent problems like this. Anyone else experience the same issue? Of course I'm now worried this will happen again at any time. I did try activating and deactivating the alarm several times. No warnings on the dash. Could the slight incline have caused fuel starvation? Seems very unlikely.
Thanks in advance for any suggestions.
~Chris
Re: Worrying experience...
Post by Shoppinit » Sun Sep 30, 2012 6:36 pm
Maybe you've got a dodgy transponder transmitter / receiver ring (that interrogates the key transponder). Can happen. If it happens again try to see if the immobiliser warning light stays on.
chrisn6
Post by chrisn6 » Sun Sep 30, 2012 6:48 pm
Thanks Shop. I did check the immobiliser warning and that went off each time. I think it started without me actually switching the alarm off/on. The keys were in the ignition and I thought, nothing to lose and 'bam', it sprang to life! Not looking forward to getting stranded soon...
~C
chrisn6
Post by chrisn6 » Wed Nov 07, 2012 6:38 pm
Hey guys & girls,
Sorry to resurrect this thread, but after 5 weeks of trouble free starting, the same exact thing happened today. This time, after about 8 or 9 attempts at turning over without a hint of firing, and a wait of a further 3 or 4 minutes while I called up the breakdown service, I turned the key while on the phone and it sprang into life! So, it is no longer an isolated incident. The immobiliser light was not on during any of the attempts so it's unlikely to be that I would think.
Do any of you think it could be the fuel pump relay? Anything else that I should look at?
Thanks again for any help.
~Chris
Simon T
Post by Simon T » Wed Nov 07, 2012 7:21 pm
Sounds like a job for MRC or Unit20 to me.
Daytona RS6 Avant, PSS9, Milltek system with 100 cell, Wagners & hoses, MRC map / 533 ps & 865 nm. Phaeton Ducts. Daily drivers / VW T5 and R1.
bakustax
Post by bakustax » Wed Nov 07, 2012 7:21 pm
You sound like you might be an unlucky cu*t
chrisn6
Post by chrisn6 » Wed Nov 07, 2012 7:23 pm
bakustax wrote:You sound like you might be an unlucky cu*t
Evidently, hahaha!! MRC and Unit 20 are too far away for me. Could be a job for Virdee...
~C
Post by chunky79 » Wed Nov 07, 2012 8:27 pm
Now now backdoor, language like that and you will upset some users
Post by Shoppinit » Wed Nov 07, 2012 9:16 pm
Could be crank position sensor. Fairly common and will prevent the engine from firing.
Post by chunky79 » Wed Nov 07, 2012 9:22 pm
Where are you based? Someone might be able to help out with Vagcom.
chrisn6
Post by chrisn6 » Thu Nov 08, 2012 10:29 am
Thanks for that Shop. Is it worth replacing the Fuel pump relay just in case or is that unlikely? Chunky, I'm in Chiswick, London. I do have the free Vagcom. Problem is, if it's all starting fine again, as it is now, will the Vagcom show up the fault?
~C
rossi46
Post by rossi46 » Thu Nov 08, 2012 10:48 am
Admittedly not on an RS6, but I had very similar symptoms on another car (Volvo) ; Despite my local garage trying various things without success, I eventually insisted they replace the camshaft position sensor and that was 2 years ago .. the car has been fine ever since.
Sorry, can't help re the Vagcom question
chrisn6
Post by chrisn6 » Thu Nov 08, 2012 10:55 am
Thanks Rossi. Looks like I'd best drop it off to Virdee. Oh well...
~C
chrisn6
Post by chrisn6 » Thu Nov 08, 2012 12:25 pm
Just wanted to say thank you to all, especially Shop. I ran the Vag Com Lite and it showed "Engine Speed Sensor (G28): no signal/communication - Intermittent". Guess I need a crank sensor! Anyone here know a cheap supplier?
Cheers,
~Chris
chrisn6
Post by chrisn6 » Thu Nov 08, 2012 12:31 pm
Found this http://www.ebay.co.uk/itm/Crankshaft-Se ... 4d05eac027
I'm sure it's much cheaper than from a stealer!
~C
Users browsing this forum: philS2 and 126 guests
