fitting wide screen sat nav 4B0 035 192P
Re: fitting wide screen sat nav 4B0 035 192P
As you can see ive tried to connect the canbus H/L from the 26 pin video plug not used in the new RNS-E but has failed to work i think this is because its not true CAN ??
What do you mean, true can?
Someone else said on this or another forum its got to be a true can connection not 100% sure myself
Hay you sorted it yet mate ? Doing mine Sunday been reading a lot of the posts do hoping all gose well !!
I still havent got it sorted inside been in bits for a week now
waiting for a guy to come and vag-com it hopefully that will work
Have a read of this see how you go ?
http://audisrs.com/archive/uk-rs6-upgra ... 32184.html
I got my addapter from eBay, I'm confused as to we're the can wires go in the addaper loom were are they on yours, the web page I found pin 5 black/white is high can and pin 6 Black yellow low can on the back of the cluster. I'm not to sure that link will work as I sent it off my phone. P.m your number if you like and I'll send you what I've found or I'll be ringing for help on Sunday lol
Yeah the link diddent work , yeah i think the can wires are orange the orange/brown stripe is always can low and the other is orange/pulple stripe can hi all ive done is tapped into these 2 wires from the grey connector behind the speedo cluster and run a wire from each one and tapped into the wires on the back of the RNS-E unit going to pins can h and can l, theres a diagrame on the top of the unit to tell you what wires to connect to not sure to put things back together yet or leave it till i got it sorted
rs6-sammy wrote:once I tap into the blue and white wire behind the Speedo and run a cable where does this wire go on the adapter plug, does it go to can h or can l as im not clear about this atm and don’t want to damage anything or blow it up
have added some pics of the blue and white wire im tapping into and a picture of the top of the new RNS-E sat nav unit with the wirering diagram
pics of wat ive done so far
you can look back on page 1 for the pics of what ive done so far
I've already told you what colour the can wires are.
Stoo listen don't people some
I feel like I've wandered into the wrong forum.
It would appear so.chunky79 wrote:Stoo listen don't people some
Users browsing this forum: Google Adsense [Bot], srichards, steve2003rs6 and 104 guests
