It would have to be benched, AFAIK that test hasn't been done. 'Broscience' would suggest that the Wagners don't add power to a standard car/setup, they might create better airflow but only if requested (by ECU) or if supporting mods were in place.swannny wrote:So has it been proved that wagners shorten the turbo life, or is just calculated guessing?
You could have the biggest intercoolers in the world but if the supporting circuit can't flow any more air or the turbos aren't drawing any more air, then how have the world's biggest intercoolers given you MOAR POWAR (a serious question, not a statement)? Which brings us 'broscience' readers to the Wagner vs. OEM prolonging turbo life... well:
- - Wagners haven't been known to leak, whereas OEMs have been known to leak within days of installation, thus giving the turbos unmetered air.
- Wagners have better cooling capacity, so 'broscience' will say they can give cooler air to the intake circuit for longer than the OEMs, this, in theory, will reduce the onset of heatsoak. I can't say if this is good nor bad for turbos (there could be arguments for and against but I'm too lazy and stupid to argue with myself).
- Wagners look way cooler than the OEMs, 'nuff said.
I'm prepared to shuffle out on a limb here, cautiously eyeing the pool of circling sharks below but more worried about the chainsaw that Shoppinit has started oiling and filling with perfect ratio two-stroke fuel - but I'll say this from my slightly worrying position; a warranty co are more likely to rely on their engineer's opinion, historical failures or fall back on their policy wording rather than do actual research involving bench tests, dynos and alternative product testing. It's just not good business sense and it ain't their bag, nor should it be but it leaves them in the same position as their customers when trying to argue something like Wagners vs. OEM.
