ATF stuff needed.
mavada
ATF stuff needed.
Post by mavada » Fri Apr 08, 2011 10:03 am
Also looking for parts to refresh my atf, planning to do it myself.
As shown in the pic i think i need the following numbers:
5
maybe 8 also
10
28
and 10 liters of oil you mentioned in your previous post:
ZF Lifeguardfluid5 (ZF No. S671 090 170):
Audi / VW Oil No. G 052162 A1 / A2 / A6
BMW Oil No. 8322 9407807
Citroen Oil No. Z 000169756
Jaguar Oil No. JLM 20238
Mercedes Benz Oil No. A 0019892203
Peugeot Oil No. Z 000169756
Porsche Oil No. 999.917.547.00
what are the costs of this stuff?
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
PhilT
RS246.com
Re: ATF stuff needed.
Post by PhilT » Fri Apr 08, 2011 11:48 am
Why not look at Opie Oils' website, or give them a call ;)
Post by bam_bam » Fri Apr 08, 2011 11:55 am
I think Mav is based in NL. Would that be an issue to use Opie?
PhilT
RS246.com
Post by PhilT » Fri Apr 08, 2011 11:59 am
bam_bam wrote:I think Mav is based in NL. Would that be an issue to use Opie?
Didn't know (No profile, or sig ;) ). Maybe Opie is not going to work out cheap enough, but might be useful as a guide :)
Post by Shoppinit » Fri Apr 08, 2011 12:56 pm
Peugeot or Citroen will probably be the cheapest. It's all the same stuff.
You need:
5 - Gasket - 01L 321 371
8 - Plug and seal - 01L 321 371
10 - O ring - 01V 321 379
28 - Strainer - 01L 325 429B
29 - Gasket - 01L 325 443
Don't think anything else is necessary.
mavada
Post by mavada » Sun Apr 10, 2011 12:48 pm
i think this will help, but i think im missing some gaskets/plugs and oil ofcourse...
http://cgi.ebay.de/Olwechselkit-Audi-A6 ... 221wt_1142
is it best to drain the atf when the box is hot, or causes that damage to it?
Yellow Koni's
Post by Shoppinit » Mon Apr 11, 2011 10:16 am
mavada wrote:is it best to drain the atf when the box is hot, or causes that damage to it?
The consequences of getting this operation wrong are severe. Don't attempt it if you're not confident of what you're doing. Not for the sake of a couple of hundred quid. I'll have a go at most things, but I got Audi to do the ATF change for me.
But in answer to your question, you won't damage the box if you drain it when hot. You might get burned if you're not careful, though. Obviously, the engine must be off when draining;
My feeling is that if it's hot, you'll get more out because 1) it'll be more viscous and 2) it'll be less dense.
mrmule
Post by mrmule » Wed May 18, 2011 2:58 pm
Shoppinit wrote:My feeling is that if it's hot, you'll get more out because 1) it'll be more viscous and 2) it'll be less dense.
Shop, do you mean less viscous; as in thinner?
SOLD - Avus RS6 Avant|KWV3|Hotchkis ARBs|RNSE|HighTech interior|Solar roof|Double glazed|Vreds|Non res Milltek|Phaeton brake ducts
VW T3|Avo 70mm drop|Subaru EJ25 motor|Audi 200 turbo trans|996 brakes|Peloquin LSD|RJES exhaust
Post by Shoppinit » Wed May 18, 2011 3:02 pm
Yes, that is what I meant :)
mrmule
Post by mrmule » Wed May 18, 2011 3:29 pm
Need to do an ATF flush as part of the warrenty on the box rebuild.
Shop, thanks for all the maintenance part numbers.
Called Opie's Oils; they are recommending as their better option Fuchs Titan ATF 5005.
Is this OK?
mavada
Post by mavada » Wed May 18, 2011 3:35 pm
yes thanks Shop and the rest for the input. :beerchug:
Yellow Koni's
Post by Shoppinit » Wed May 18, 2011 3:45 pm
Is this OK?
No, don't do it. Use the proper stuff from one of the above-mentioned places. If you needed a blood transfusion and were AB- you wouldn't want some O+ even if it came from a body building champion with an IQ of 200+.
mrmule
Post by mrmule » Wed May 18, 2011 3:53 pm
So where did all these get documented as acceptable?
Post by Shoppinit » Wed May 18, 2011 4:01 pm
mrmule
Post by mrmule » Thu May 19, 2011 8:28 am
Cheers shop; I'm gonna call Citroen later and get a price.
Users browsing this forum: Majestic-12 [Bot] and 274 guests
