Suspension Top Mounts...advice...?????
grizz
Post by grizz » Wed Mar 12, 2008 6:36 pm
They don't come with the new shocks , when the shock is removed you can then see any damage . price and pic in the sticky .
Unit 20
0151 3366888
Lig
Post by Lig » Thu Mar 13, 2008 12:10 am
Thanks Grizz,
I assume the first pic in the sticky is the alloy mounts for the rear shocks and the second pic is of the rubber bushes for the fronts??!!
Cheers,
Lig.
PoRToS
Post by PoRToS » Sun Nov 22, 2009 4:57 pm
Hi all,
Thought of taking this old thread up, since my RS6 is going for a DRC total repair in January. It is paid by Audi 2 year parts warranty, since the DRC was last changed 04 2008.... *sigh*
I have a couple of questions,
1) What else should I have changed at the same time, the top mounts discussed in this thread obviously, but also something else?
2) With the new drc system, will the springs on the shock also be new? Or are they taken from the old drc shocks? Tried searching for this info, but cannot find anything...
All help is appreciated!
philroach
Post by philroach » Sun Nov 22, 2009 6:22 pm
would these rubber bushes be replaced as part of an H&R installation ?
Now : XFR Jag 5.0 Supercharged
Used to have : C5 Daytona Avant , silver leather , carbon inserts ; RNSE, TV in motion, Bluetooth , well filled SD card slots ; PSS9's ; Hotchkiss ARB's ; Miltek cat back res ; Wagner intercoolers ; Phaeton brake ducts ; forge DV's ;
Post by Shoppinit » Sun Nov 22, 2009 6:27 pm
Yes, they are dirt cheap and should be changed.
PoRToS, they'll use the same springs. Nothing wrong with them. Hopefully they'll do a good job for you.
RS6Steve
Post by RS6Steve » Sun Nov 22, 2009 7:34 pm
Just had mine changed, £60. You might also want to consider your upper arms whiles it's all off. About £65 each.
Post by Shoppinit » Sun Nov 22, 2009 7:41 pm
He means consider changing them, rather than just staring at your biceps ;)
PoRToS
Post by PoRToS » Tue Nov 24, 2009 11:52 am
Shoppinit wrote:Yes, they are dirt cheap and should be changed.
Hmm. Only a thought - don't the springs get old & tired too? If they use the same springs. Since my RS6 is 110k Miles and 7 years old...
Or does the DRC affect the wear on the springs too?
For the upper arms, are they difficult to change by themselves? Or are they just probably shot anyway?
Trying just to keep the costs lowish :lol: , but not to "dumb"-save.
Post by Shoppinit » Tue Nov 24, 2009 12:49 pm
I don't think you need to change the springs. Can't see the point if they're not broken. As far as I am aware, they don't wear. As long as their elastic limit isn't exceeded, they should work as well as when new. Maybe someone who knows more about springs can correct me.
The control arms are easy to change. Saves time doing it when the shocks are out. Either way, it's not a big job.
Users browsing this forum: Google [Bot], TechNick and 44 guests
