fitting rnse into b5
Posted: Sun Feb 28, 2010 7:55 pm
by dvillian2
hi fitting rnse into my rs4 b5 which had rnsd with sat nav and tv do i take all the old stuff out tv tunner and and sat nav in boot and cd multichanger? is the sat nav all built in to rnse ? I have a alpine digital tv ariels how do i wire this in to rnse ANY HELP WOULD BE MUCH APPRECIATED THANKS ALAN
RE: fitting rnse into b5
Posted: Sun Feb 28, 2010 8:08 pm
by PetrolDave
You also need to remove the TMC tuner - this converts the CAN bus from Audi into Bosch which the RNS-D needs but which will cause the RNS-E not to be able to communicate with the car.
To connect the Alpine TV tuner you'll need a multimedia adapter, see the Kufatec website.
Posted: Mon Mar 01, 2010 1:06 am
by Golfather
Not strictly true, this can remain in situ, you can get true CAN signals for the RNSE from elsewhere in the car.
Posted: Mon Mar 01, 2010 9:30 pm
by Virdee Autos
yes sat nav built into RNS-E
As said you need a multimedia adapter for Alpine, and also a IR eye to control the TV tuner
And you can get CAn signal from instrument cluster, with a bit of re-wiring, and VCDS coding.
Re: RE: fitting rnse into b5
Posted: Tue Mar 02, 2010 8:28 pm
by PetrolDave
But it's shed loads easier to remove the TMC tuner and just join the CAN wires together, than mess around routing wires from the cluster!
RE: Re: RE: fitting rnse into b5
Posted: Tue Mar 02, 2010 10:11 pm
by dvillian2
were do i find this tmc tuner and why dosnt rnse need it ?
