BT connected but no sound?
Posted: Thu Jul 31, 2008 9:53 pm
by Declan
Phones connect to my B7 RS4 but no sound when calling.
Has any one come across this before?
RE: BT connected but no sound?
Posted: Fri Aug 01, 2008 6:11 am
by Greengoblin
I seem to have the same problem........
It even displays the incoming number in the DIS!
I don't have a Multi function steering wheel, so I have no button to push to answer the call.
Not an RS4 mind, I have a B6 S4 with RNS-E.
Posted: Fri Aug 01, 2008 11:27 am
by dubwhizz
ive had a similar problem with my parrot ive been trying to install. apparantly the audi head units need a feed from the blutooch receiver (in my case the parrot) into the 4th iso block (red vertical one) for it to be able to output the sound. This is cos the audi stereos work on low level outputs and the y harnesses with the parrot supplies a hogh level input to the stereo, which it does nothing with.
don't know if that applies to what you chaps are doing?
Re: BT connected but no sound?
Posted: Fri Aug 01, 2008 12:25 pm
by PetrolDave
Declan wrote:Phones connect to my B7 RS4 but no sound when calling.
Do you mean no ringtone, or no audio when in a call?
It is possible to turn the volume down to zero, so try ringing your mobile and then turning up the volume control on the radio/RNS-E and on the phone - both have to be turned up.
Re: RE: BT connected but no sound?
Posted: Fri Aug 01, 2008 12:26 pm
by PetrolDave
Greengoblin wrote:I don't have a Multi function steering wheel, so I have no button to push to answer the call.
When the phone rings all you have to do is press the big button on the RNS-E to answer the call - assuming your phone is paired with the car.
Posted: Sat Aug 02, 2008 4:43 pm
by Greengoblin
On reflection, I'm guessing that the fact that I have taken off the factory fitted cradle (the holes that this left are another matter) and have not connected the wires to the RNS-E may be the problem, no provision on the Kufatec loom that I ordered.
P.S. sorry if I'm hi-jacking this thread Declan, it may be related. :)
Posted: Sun Aug 03, 2008 8:37 pm
by Declan
Now working. plug for speakers was not connected.
Dealer sorted it,
1st owner had a after market kit which was removed,
Thanks all for posting.
Declan..
