fan noise after taking keys out
Posted: Fri Dec 22, 2006 8:24 am
by RSVI
Not had the car that long (RS6) but last night i noticed a noise when I'd taken the keys out.
Sounded like an interference sound you'd get from an unturned TV.
First i thought it was coming from the TV/radio but then worked out it was coming from the centre air grills on the dash, sounded like a tiny fan working.
Anyone enlighten me on this one?
RE: fan noise after taking keys out
Posted: Fri Dec 22, 2006 9:48 am
by claudefrog
if its anything like the 1.8t engine it could be you are hearing the electric water pump running, this pumps coolant around the engine and turbo for 10 minutes after you stop the car.
Posted: Fri Dec 22, 2006 10:02 am
by PetrolDave
IIRC the RS6 also has an auxiliary water pump (to remove the heat from the turbo centre bearings).
Posted: Fri Dec 22, 2006 1:28 pm
by RSVI
That makes sense
Does that mean it's not so important to leave engine running for a while after a hard ish drive?
If so i guess a turbo timer is a waste of money
Posted: Wed Jan 03, 2007 10:21 pm
by derdle
Always let the engine idle after a good run!
Posted: Wed Jan 03, 2007 11:20 pm
by david7m
Letting the car tick over before switching off lets the turbo spool down to its lowest rpm so bearing wear from oil starvation (no oil being pumped around when engine is off) is at a minimum, plus heat is taken away from the turbo.
Therefore, as per Derdle, ALWAYS let it idle after use ;)
Dave
