Handsfree and bluetooth for B7 RS4
Posted: Fri Jan 01, 2016 3:56 pm
by sjjhr
Hello. I have a B7 RS4 with Bose Symphony system. Is there a way to (i) get it to pair with a modern phone to use the system handsfree? (ii) source music from an iPhone or digital device?
Many thanks in advance. S
Re: Handsfree and bluetooth for B7 RS4
Posted: Sat Jan 02, 2016 5:55 pm
by PetrolDave
sjjhr wrote:Hello. I have a B7 RS4 with Bose Symphony system. Is there a way to (i) get it to pair with a modern phone to use the system handsfree? (ii) source music from an iPhone or digital device?
(i) Retrofit the OEM Handsfree kit which uses Bluetooth - this is how I connect my iPhone6+
(ii) (a) OEM method - replace the RNS-E with a 2010+ model and replace the CD changer with an AMI fitted with a Tune2Air Bluetooth adapter
(ii) (b) Non-OEM method - fit one of the aftermarket Bluetooth Aux In adapters.
Posted: Sun Jan 03, 2016 9:53 pm
by sjjhr
Thanks for your reply. I don't have the RNS-E - I have 6CD Bose Symphony CD head. Does anyone have a solution for my original questions please?
Posted: Mon Jan 04, 2016 6:53 pm
by PetrolDave
sjjhr wrote:Thanks for your reply. I don't have the RNS-E - I have 6CD Bose Symphony CD head. Does anyone have a solution for my original questions please?
My answers (i) - if you have an MFSW - and (ii)(b) still apply to a Symphony II as fitted to a B7.
Posted: Tue Jan 05, 2016 12:19 am
by sjjhr
Thanks - have you used a particular supplier and fitter? I've looked at the head unit and it doesn't look easy to remove without damaging the console
Posted: Tue Jan 05, 2016 11:54 am
by RossDagley
sjjhr wrote:Thanks - have you used a particular supplier and fitter? I've looked at the head unit and it doesn't look easy to remove without damaging the console
There are 4 keys that slot in to remove (picture shows RNSE but same slots are on yours):
Posted: Tue Jan 05, 2016 12:00 pm
by sjjhr
Thanks, appreciate the tips as I learn about this car
Posted: Tue Jan 05, 2016 6:56 pm
by PetrolDave
RossDagley wrote:sjjhr wrote:Thanks - have you used a particular supplier and fitter? I've looked at the head unit and it doesn't look easy to remove without damaging the console
Try and get the keys with plastic coating on the rings where you hold them - unless you like the sight of your own blood
