Cheap bluetooth streaming - External AV req
barryrs
Post by barryrs » Wed Jul 30, 2014 3:01 pm
Hi guys,
Thought I would share my recent cheap Bluetooth music streaming solution for others as looking on the web didnt turn up much.
Total cost of the install was just circa £45
The parts required are as follows
1. Connects2 CT29AU02 lead. I got mine here - http://www.ebay.co.uk/itm/160690745278? ... 1497.l2649
One thing to note is that there was a manufacturing fault with my first lead where the left and right negatives had separate pins when they should be joined giving you 5 pins to plug in.
Installation instructions are here - http://www.connects2downloads.co.uk/c2/ ... 29AU02.pdf
Although my layout looks different it was just a case of removing 3 nuts and 1 bolt and the whole cage lifted and swung into the boot for easy access.
2. Ipod to RCA including power lead here - http://www.ebay.co.uk/itm/130733565203? ... 1497.l2649
You simply need to locate a suitable live and earth point in which to wire this in and connect to the above lead.
3. Generic Bluetooth receiver such as - http://www.ebay.co.uk/itm/221402870065? ... 1497.l2649
This receiver needs a power source as the lead above and negates the need for battery’s
4. Generic CAN-BUS ignition generator as theres no switched live in the boot - http://www.ebay.co.uk/itm/150375318803? ... EBIDX%3AIT
All in all a very simple install and works perfectly with my factory fit telephone prep by fading out the music when a call is received and continuing once the call has ended.
Well pleased :rocker:
Rs4andy
Re: Cheap bluetooth streaming - External AV req
Post by Rs4andy » Sat Jan 10, 2015 6:32 pm
hi just received all the parts required but not sure what colour wire goes in which pin on the plug can you help Thanks Andy
Return to “Electrical”
Users browsing this forum: No registered users and 10 guests
