BT connected but no sound?
Declan
Post by Declan » Thu Jul 31, 2008 9:53 pm
Phones connect to my B7 RS4 but no sound when calling.
Has any one come across this before?
Greengoblin
RE: BT connected but no sound?
Post by Greengoblin » Fri Aug 01, 2008 6:11 am
I seem to have the same problem........
It even displays the incoming number in the DIS!
I don't have a Multi function steering wheel, so I have no button to push to answer the call.
Not an RS4 mind, I have a B6 S4 with RNS-E.
2004 S4 Avant
dubwhizz
Post by dubwhizz » Fri Aug 01, 2008 11:27 am
ive had a similar problem with my parrot ive been trying to install. apparantly the audi head units need a feed from the blutooch receiver (in my case the parrot) into the 4th iso block (red vertical one) for it to be able to output the sound. This is cos the audi stereos work on low level outputs and the y harnesses with the parrot supplies a hogh level input to the stereo, which it does nothing with.
don't know if that applies to what you chaps are doing?
PetrolDave
Re: BT connected but no sound?
Post by PetrolDave » Fri Aug 01, 2008 12:25 pm
Declan wrote:Phones connect to my B7 RS4 but no sound when calling.
Do you mean no ringtone, or no audio when in a call?
It is possible to turn the volume down to zero, so try ringing your mobile and then turning up the volume control on the radio/RNS-E and on the phone - both have to be turned up.
PetrolDave
Re: RE: BT connected but no sound?
Post by PetrolDave » Fri Aug 01, 2008 12:26 pm
Greengoblin wrote:I don't have a Multi function steering wheel, so I have no button to push to answer the call.
When the phone rings all you have to do is press the big button on the RNS-E to answer the call - assuming your phone is paired with the car.
Greengoblin
Post by Greengoblin » Sat Aug 02, 2008 4:43 pm
On reflection, I'm guessing that the fact that I have taken off the factory fitted cradle (the holes that this left are another matter) and have not connected the wires to the RNS-E may be the problem, no provision on the Kufatec loom that I ordered.
P.S. sorry if I'm hi-jacking this thread Declan, it may be related. :)
2004 S4 Avant
Declan
Post by Declan » Sun Aug 03, 2008 8:37 pm
Now working. plug for speakers was not connected.
Dealer sorted it,
1st owner had a after market kit which was removed,
Thanks all for posting.
Declan..
Return to “Electrical”
Users browsing this forum: No registered users and 19 guests
