Bouncing/choppy ride
Posted: Wed Aug 10, 2022 12:59 am
by Tim634883
Hi All,
I’m new to this group having recently purchased a 2018 RS4 in the UK.
I’m finding the ride pretty choppy and it bounces a lot even on ‘smooth’ UK motorways in comfort/auto. Switching it to Dynamic suspension makes it firmer so less bounce but then also unbearable on a long motorway drive.
I sold my 991.1 to fund this RS4 so I’m used to firm and low ride height sports cars but I never had this sense of chop like being on a poor ferry crossing.
I’ve checked the tyre pressures. Fronts are 41 and rears are 32. The recommended pressures look to be 38/32. Will 3psi really make a dent to smooth out this chop?
Or is there something else I could try?
Any help/thoughts/explanations are welcome.
Thanks, Tim
Re: Bouncing/choppy ride
Posted: Wed Aug 10, 2022 6:48 pm
by RS4John
Welcome, so the 1st question would have to be what kind of suspension have you got? The RS4 was available with an option - DRC - Dynamic Ride Control. If you don't know then the MyAudi App will enable you to check the specification of the car.
I would have thought 41 PSI is kind of high on the fronts - you'll end up wearing the middle of the tyres out.
Posted: Thu Aug 11, 2022 12:47 am
by Tim634883
Thanks for the response.
I’ll double check on the My Audi app, but I’m pretty sure it doesn’t have the DRC. I assume this option would have reduced that chop.
If 41psi is high as you say what would you recommend as the optimal balance between fronts and rears?
Thanks, Tim
Posted: Thu Aug 11, 2022 9:04 am
by RS4John
Audi place a Sticker on the end of the passenger front door I recall - with the recommended pressures. For my current RSQ3 I run the same pressures all round @ 36 PSI.
The choppy ride might be shot shock absorbers, my RS4 has almost every option (ex Press car) including DRC. The feature robbed the RS4 of the fun factor for me - it was too near perfect and not in any way scary which to my mind an Audi RS ought to be.
Posted: Thu Aug 11, 2022 9:07 am
by Brooner
If your running 20" 275s it's 38 psi front 32psi rear
41 psi front and rear for a fully laden car
I run mine on the 38 / 32 with no issues my car is on DRC
Posted: Thu Aug 11, 2022 9:08 am
by RS4John
Thanks Brooner!
Posted: Thu Aug 11, 2022 9:15 am
by Brooner
But unless you can do back to backs with a similar
set up it might just be the suspension is firm
I run mine in dynamic and most people think this is a hard crashy ride but I seem to be used to the set up not any harder or crasher than my last RS4 with DRC
Posted: Thu Aug 11, 2022 8:45 pm
by Tim634883
Thanks all. I’ll lower the psi to 38 front and double check the 32 rear and see what that does.
Otherwise I might look into the shock absorbers to see what state they are in.
It feels like the F1 Merc this season 😅
