Wheel nut torque sttings
Posted: Sat Apr 17, 2021 5:51 pm
by Munchingmolar
Anyone ? Seen various from 90 to 105 ft lbs !
Re: Wheel nut torque sttings
Posted: Sat Apr 17, 2021 8:25 pm
by Dannyboy123
Audi spec for the RS4 is 120nm
Posted: Sat Apr 17, 2021 11:21 pm
by PieterZ
Correct.
Posted: Sun Apr 18, 2021 8:55 am
by Brooner
Yep 120 nm just change to my summer wheels this is the torque setting i use and re check the torque after a 30 mile run
Posted: Sun Apr 18, 2021 9:28 pm
by Munchingmolar
Posted: Thu Feb 03, 2022 2:02 pm
by RS Owner
and 120 Nm is 90 lb-ft so the lower end of your estimate
Posted: Fri Jul 15, 2022 3:21 pm
by StewamEmiya37
Suppose you tighten the fasteners with less force than necessary, then under the influence of vibrations. In that case, the threaded connection can unwind without providing the necessary tightness between the fastened parts, which can lead to serious consequences. On the contrary, if you apply more force to the hardware than is required, the destruction of the threaded connection or the fastened parts will occur; for example, a thread failure or the appearance of cracks in the parts may occur. In addition, remember that you need to buy special bolts. I recommend a store where I always buy power tool accessories and hardware. I think you'll find everything you need there.
Posted: Sat Jul 16, 2022 7:17 am
by Brooner
There you go 120nm from the owners manual
