Spark plug upgrade
2.9 V6 24v TFSI - 444 bhp
Brooner
Spark plug upgrade
Post by Brooner » Sun Aug 18, 2024 10:19 am
Folks
Anyone recommend is it worth upgrading from the oem RS4 spark plugs as mine are due to be replaced after 43k on the clock
And if so which ones are recommended
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Jools
Re: Spark plug upgrade
Post by Jools » Sun Aug 18, 2024 2:40 pm
Just a few questions, why not use the recommended NGK SILKGR9A7ES?
Is your car standard or tuned?
Are you having ignition / performance problems?
What increase in 'performance' are you thinking you may gain by changing the plug type?
What does your tuner say you should be running?
Don't forget running a hotter or colder plug can cause ignition problems that can lead to engine damage in some cases.
I'm sure for a standard performance car Audi don't just throw any old spark plug in and pray.
Some tuners even recommend using original factory plugs and coil caps.
Just asking.
Brooner
Post by Brooner » Mon Aug 19, 2024 8:22 am
car is standard
just throwing the question out there to see if there is any benifits for a upgrade
Users browsing this forum: RS Owner and 18 guests
