Aftermarket towbar
2.9 V6 24v TFSI - 444 bhp
applecrate
Aftermarket towbar
Post by applecrate » Mon Apr 15, 2024 5:51 pm
Hi all, getting geared up for the new arrival later this week & need a towbar, ideally retractable or removable. Am only going to be towing a trailer for camping (brenderup 1250).
I emailed my usual fitter but they said their towbar suppliers reckon they do not make a towbar for the RS4 avant which sounds a bit odd. Can anyone either confirm if a standard A4 towbar of the same year model will fit the RS? Or ideally, if anyone can point me towards a RS4 specific one?
TIA!!
Jools
Re: Aftermarket towbar
Post by Jools » Mon Apr 15, 2024 8:55 pm
Does your car have DRC?
If so, you can't fit a towbar as the DRC central valves and there pipework are mounted under the rear boot section and are in the way of the towbar fitting frame.
If no DRC, it looks like https://www.automotive-control.co.uk/au ... e-tow-bar/ have a Westfelia solution.
Rwg
Post by Rwg » Tue Apr 16, 2024 12:52 am
I gad local garage fit a hidden tow bar using geniune Audi harnes when 1st bought new 2019 £650 but no DRC
applecrate
Post by applecrate » Tue Apr 16, 2024 3:48 pm
Cheers for the comments guys. I spoke with my local fitter who has done all my previous audis & he said he wont touch it due to Audi no being cooperative or will to share technical details to ensure wiring esp is not going to break anything.
Jools
Post by Jools » Tue Apr 16, 2024 9:13 pm
applecrate I've attched a few pages from the Audi manual about the towing bracket and electronics.
I found an A6 towbar retrofit pdf which maybe similar.
I've also got the electrical wiring diagrams as well if that's any use to you.
Towbar Retrofit EBA_4K0055204_en_180613.pdf
(1.06 MiB) Downloaded 56 times
elchet
Post by elchet » Fri Apr 19, 2024 9:26 am
Out out interest, where have you got that Audi manual from? Looks like it's super detailed!
2018 B9 RS4 Daytona Grey
Jools
Post by Jools » Sat Apr 20, 2024 3:10 pm
elchet
Yes I have the full A4 B9 Audi manual including the RS4, a copy happened to come up on ebay not long after I got mine, to compliment my VAG-COM cable.
It has proved very helpful on several occasions. The only down side is your Audi dealership doesn't like it when you know more about your car than they do!
