Tapatalk Search not working
I can't use the search function, just comes up with an error message. Used to work ok
Re: Site slow down
That's likely to be unrelated. Please provide a screenshot if it happens again.Rw@@dy wrote:I can't use the search function, just comes up with an error message. Used to work ok
Re: Site slow down
PhilT wrote:That's likely to be unrelated. Please provide a screenshot if it happens again.Rw@@dy wrote:I can't use the search function, just comes up with an error message. Used to work ok
Re: Site slow down
As mentioned before, I suspect this could be Tapatalk as I had a similar issues earlier
Does this:-
1. Happen at a particular time of day?
2. What device are you using?
3. What browsers are you using other than Tapatalk and does it happen there?
Does this:-
Re: Site slow down
Just tried again and has the same error message both on iPad and iPhonePhilT wrote:I think I fixed the performance issue.
The search issue seems to be Tapatalk, Can you test it again please?
Re: Site slow down
What are you searching for?
Re: Site slow down
Tried a few things, last one was coilovers
Re: Site slow down
Works for me search.php?keywords=coilovers
I'll split this thread for what seems to be a Tapatalk search issue. Let's see if anyone else has the same problem.
Users browsing this forum: No registered users and 27 guests
