IanH's C6 RS6 - 925hp & 1150nm - Updated 06 Jun '25
Re: IanH's C6 RS6 - 955hp & 1200nm - Updated 09 Feb '24
Post by Ian_C » Tue Dec 03, 2024 7:09 pm
Dodged a bullet there with the tyres and the missing wheel bolt! :o
IanH755
Post by IanH755 » Thu Dec 05, 2024 11:24 pm
Yeap, mostly just a consequence of my own lack of attention down to just not driving the car anywhere near as much as I should be.
IanH755
Post by IanH755 » Fri Jun 06, 2025 6:25 pm
So after a quiet 6 months, what's new? Well pull up a chair and let me tell you the tale of how a simple exhaust change reminded me that - my maths maybe not be same as everyone else's maths, which caused a bit of an issue!
First some history on my exhaust - originally this was a complete Frankenstein's monster, with an MRC Tuning set of 3.5in to 3in de-catted downpipes leading to a custom 3in removable cat/de-cat section, then a KWE 3in cat-back bought from Germany which turned out was jigged incorrectly and needed a load of custom work to fix, no resonators and no X or H pipe linking the two exhaust pipes (so effectively each 3in exhaust pipe was only linked to half an engine i.e. a 475hp 2.5L I5).
What were the issues - well, to start, having to swap the cat back/forth at MOT was always a bit of a pain to do (arrive at garage, let exhaust cool, remove de-cat and fit cat, go for a blast to heat up cat to pass MOT, go to MOT place, come back to garage after MOT, let exhaust cool again, remove cat and fit de-cat, go home), and whilst I absolutely loved the "raw, aggressive and loud" noise and tone made by this hodgepodge of an exhaust, to everyone else it was "raw, aggressive and loud" as well, to the point that not only were the neighbours quietly twitching curtains and raising pitch forks every-time I went for a drive, but it was so loud that even my mates 10yo kid didn't want to go in the car anymore because it hurt his ears etc etc.
So, knowing that I won't be keeping this forever, and who ever owns this next likely won't be happy with a family car that could deafen the dead, and in an effort to solve my Cat/De-Cat pains, I decided to get a whole new custom exhaust to join onto the existing downpipes. First off I knew I wanted to permanently fit a set of cats, just to make MOT time so much easier, so I looked around for a set of Cats which would "easily" pass an MOT - This was a big mistake and caused every other problem I'll tell you about later - My old cats were about 10 years old, made by ARLOW in Germany and were a 100cell Euro 4 metallic cell Cat which sometimes still struggled to pass emissions and were getting worse with every MOT so I didn't want to reuse these.
After a search I decided to go "overkill" and get a set of 400 cell, Euro 6 metallic Cats - so more cells and a "better" chemical dope applied to remove even more bad stuff from the exhaust gas (wow, so technical :D). Now I knew more cells = more restriction so I looked up "how restrictive is a 400 cell cat" on the mighty Google, and the general consensus from a few places was that, for a metallic structure like mine, it was about a 10% restriction so I thought "if I buy a 4in wide cat, then if I knock off 10% = 0.4in which means the 4in wide Cat will flow the same volume of gas as a 3.6in exhaust - so no restriction at all, winner!!!!" and bought a pair of these from Alpha Performance Fabrication.
Next I needed a custom fabricator, and having had a look around my "local-ish" area of Norfolk I'd seen that Demand Engineering near Diss had done a quite a few custom exhaust for other C6 RS6 with similar power levels, only I found out they no longer do custom work and only do Land Rovers, so I looked around again and eventually found Edwards Motorsport near Kings Lynn who do all kind of custom metal work (cages, exhausts, manifolds etc, any custom metal work really), and I knew the name seemed familiar but couldn't quite place it, until during a web search it turned out they'd been involved in fitting an RB26DETT engine from a Skyline GTR into a Lotus which had its own thread on the GTR Owners club, and I was still a member of the club so remember reading about it (small world).
Anyway, after a visit to confirm what they could do based on what I wanted which was to stay with 3in pipes and then go from the existing downpipes into my supplied cats then X-Pipe - resonators - quieter back boxes - finally re-using my existing oval tips - we shook hands and I left the car with them for a month whilst I pootled around in the Citroen C1.
Now, I knew that I'd have to get the car map checked out after having this work done as, even though "I'd done all my calcs and I knew it was OK" I juuuust wanted to be sure that the cats and the exhaust weren't somehow a restriction or were maybe just a tiny one at worse (ah hubris in action!). After picking up the car the difference was amazing, just what I wanted with the volume levels (almost OEM) I wanted, so now you could actually talk to a passenger rather than shout at each other and my stereo didn't have to be turned upto 11 to drown out the droning past 40mph.
Happy with my choice in fabricator (great welding work BTW!) I drove down to MRC Tuning a few days later and let Doug loose only to have him return after a few pulls looking very unhappy for me - the issue was that my "amazingly well calculated Cats restriction frontal area maths" actually turned out to be utter rubbish, and the cats were such a massive restriction that, to the car, it seemed like the OEM 2.5in exhaust had been refitted, with the car (previously 955hp & 850lbs/ft) had now dropped to 750hp & 666lbs/ft with some impressive lag and it was obviously not being happy about being unable to breath out properly, with Doug being concerned that, with the RS6 not having any EGT's from the factory, he couldn't be sure just how hot the exhaust was getting so he wasn't confident that it was safe at full throttle, even if down tuned.
Ah balls!
So, with Doug giving me a sort of "emergency" map of wastegate only boost and a promise not to go full throttle until the problem was fixed, I trudged back home to figure out what to do next, other than the already made decision to cut out these restrictive (for my car) Cats. I decided to ring Edward Motorsport in a flapping panic and they were able to grab some spare time to chop out the Cats for me and stick in a "temporary" swappable cat/de-cat section, which immediately solved my "OMG the engines gonna melt" issue and would give me time to come up with a better plan.
I also had to travel back down to MRC Tuning for Doug to undo his previous map and find out how restrictive the new exhaust was, being much, much quieter than the one which made 955hp - this time Doug was full of smiles for me, 925hp & 850lbs/ft with no issues, so a small 30hp drop to solve a massive volume/noise problem, I was very happy with that!
Well, now I've got a decision to make -
* A - Stay with the swappable cats and just re-use the "restrictive" Cats for MOT only as the car won't be doing over 3000rpm with them fitted - zero cost option but back to the same old "in/out" issue with the cats.
* B - Find a set of non-restrictive cats to have permanently fitted and another remap for them. This solves the Cat in/out issue but chucks in a big one in its place. I spoke to HJS who make Cats for high power cars like mine (which I should have done in the 1st place) and they recommended the biggest Cat they do - a 6in 200 cell Euro 6 one - which they guarantee will not restrict a 3in exhaust at 450hp (so 900hp for my twin exhaust). So whats the issue - the cost, they're £1000 each :eek:
So after many, many thousands of pounds, 500+ miles back and forth to MRC etc I'm effectively back in the same situation I was at the start of all this................but my cars quieter soooooooo :thumb:
Also, and just to repeat this, Edwards Motorsport really has done some fantastic work for me, all of this faff was created solely by me and my smooth brain!
Here's some pics anyway -
750hp -
back to 925hp -
don0301
Re: IanH's C6 RS6 - 925hp & 1150nm - Updated 06 Jun '25
Post by don0301 » Sat Jun 07, 2025 9:54 am
Just find a garage that will give a ticket pass. Easy
Ferrari 296 GTB
992 Turbo S
Ferrari 488 Spider
C6 RS6
E46 M3 convertible
Nissan 200sx mk 2
Vauxhall Senator
Ford Sierra 1.8LX
Peugeot 205 1.9 GTi
Vauxhall Belmont SRi
Vauxhall Astra 1.3
Vauxhall Astra 1.3
1st car Datsun 120 FII Lime green....yeah :shock:
IanH755
Post by IanH755 » Sat Jun 07, 2025 1:44 pm
If only it was that easy! I spoke to both MRC and Unit20 who can't find a local "friendly MOT" place anymore, and there's absolutely no-one close to me in Norfolk who are "emissions friendly" either, and all this (according to a few places that told me) is apparently down to a massive crackdown by DVSA and large numbers of "caught being too friendly" testers losing their certification.
I mean, if I could just pop around to my local place for a simple emissions sign-off, I'd be there in a heartbeat - and I'm sure there's still some friendly MOT places about, but finding one has become a pain where I live.
don0301
Post by don0301 » Wed Jun 11, 2025 11:38 am
I never had a problem in Essex, When I moved to N. Somerset 3yrs ago I had similar experience at first but it's just because they "don't know you" I found somewhere easily enough. Word of mouth is probably your best bet.
You won't get any answer from anyone like MRC or Unit 20, that should be obvious.
Ferrari 296 GTB
992 Turbo S
Ferrari 488 Spider
C6 RS6
E46 M3 convertible
Nissan 200sx mk 2
Vauxhall Senator
Ford Sierra 1.8LX
Peugeot 205 1.9 GTi
Vauxhall Astra 1.3
Vauxhall Astra 1.3
IanH755
Post by IanH755 » Sun Jun 22, 2025 10:29 pm
For the first time in what seems like forever, I took my car out to display it at a car show, so today I was at Cambridgeshire's largest car show, the 4KAutoShow held at Newmarket Race Course.
There was around 500+ cars on display (my pics just show 1 of the 3 display areas), from various clubs around the area with everything from a Porsche 918 to a rusty VW Polo and everything in-between. With such a varied line up there was literally "something for everyone" and when combined with the awesome sunny weather we're having the day was absolutely fantastic!
I used over 1/2 a tank of fuel in under 100 miles travelling there & back with lots, and lots, and lots of full throttle used on the drive, and despite being a little unsure of how much I'd like the quieter exhaust after nearly a decade of ear-bleedingly loud noise, this trip really showed me how fantastic it is.
Anyway, some pics -
and something thats rare in the UK, when the sun finally comes out the green & purple flake in the paint comes out, taking away some of that "grey box" look to the car to the naked eye (not great at coming across in pictures sadly).
Post by Ian_C » Wed Jun 25, 2025 12:17 pm
Looking lovely. 8)
IanH755
Post by IanH755 » Fri Jul 04, 2025 1:21 pm
Ah................................some people have no sense of humour!
Luckily for me, this wasn't a legal issue but instead it was the Police coming to my rescue after I broke down alongside an NSL main road and they helped tow me to a local petrol station for my safety.
As for the breakdown, whilst at full throttle at somewhere around 5500-6000rpm, the car "jerked" twice within 1/2 a second and immediately lost all engine power (but still running) with zero throttle response. There were no warning lights, no noises, no smoke, nothing - the engine was in overrun as the revs died down slowly from 5500-6000rpm down to 1000rpm whilst I braked and, as my speed dropped to <20mph, the revs which were holding at 1000rpm-ish then dropped to 0rpm and the engine shut off leaving me the last 15mph to 0mph with no assisted brakes/steering.
The car cranks on the starter but will not start and my initial thoughts were that it sounds like there's either no fuel at all getting to the engine (1x LP fuel pump intank, 2x HP fuel pumps in the engine bay and I've got 2/3 of a tank of fuel) or all 10 sparks are not firing for an ECU reason (almost like the immobiliser is active).
I got the car low-loaded home and ran my VCDS software which shows that the intank fuel pump is getting a command to run, the fuse for the fuel pump relay is good and during cranking the fuel rail pressure does change, there are no fault codes at all (other than an instrument cluster adaption code I've had since owning the car), I've got a multi-map ECU so I changed map and the fault is still the same on both driving maps, I checked the fuel readings via live data and can see fuel pressures etc so the sensors are working etc. I started to take the LP fuel feed line off the drivers side HP fuel pump in the engine bay and that squirted some pressurised fuel so I'm hoping that means that there's no splits in the pipework (which would've dumped that pressure) and that there's fuel getting to the HP pumps.
At this point I'm thinking its less likely fuel (from my very limited fault finding - could still be wrong) and more likely something ECU based so I spoke to MRC who mapped the car and I'm getting it low-loaded to them in a few weeks hopefully, just dealing with transport companies, and I'll report back when we know whats failed.
IanH755
Post by IanH755 » Sat Jul 12, 2025 4:26 pm
Fault Finding Update - still awaiting delivery to MRC, but here's what I've found whilst tinkering about with VCDS:
Previously I ran my VCDS software which shows that the intank fuel pump is getting a command to run, the fuse for the fuel pump relay is good - The update is that now I've checked that the 30A fused link on the battery is good which directly powers the pump and, using VCDS, during cranking the single low pressure fuel sensor (used by both ECUs) can be read by ECU 1 (cyl 1-5) and its reading about 6.XXBar which changes slightly during cranking.
There is also a Fuel Regulator value in ECU 1 (I don't know if its for low or High fuel pressure but guessing Low) which is about -241 and also changes during cranking and I guess that is what the ECU uses to control either the low or high Fuel Pressure with the sensor providing feedback. Finally the ECU 1 High Pressure Fuel sensor is reading from 40-100Bar during engine start which seems correct.
However the low fuel pressure sensor and regulator values in ECU 2 (cyl 6-10) are rock steady at 12.00Bar and -2500 and don't move during cranking, so I guess thats the sensors max value and then the ECU going max input on the regulator to try to reduce it. The high fuel pressure as read by ECU 2 reads 40-100Bar when cranking which, again, seems correct.
I checked the wiring diagrams for the single LP fuel sensor (G410) used by both ECUs and it only has 3 wires (earth, +5v and Signal) and that the Signal wire only goes to ECU 1 (J623). At that point I don't know if ECU 1 is then supposed to send that signal to ECU 2 for it to use or not, but I would "guess" that it is.
Based on that guess, if it is supposed to send that signal from ECU1 to ECU2 and ECU 2 isn't seeing the correct low fuel pressure signal, I don't know if that would that cause both ECU's to cut any spark signals as a safety choice i.e. if one bank (cyl 5-10) can't control the LP fuel pressure via the regulator, does that ECU then tells the other ECU not to fire also etc?
If thats the case, then as ECU 1 can "see" the pressure reading but ECU 2 can't, I wonder if there's an electrical issue between both ECU's with the wiring or, alternatively, if some of either ECU 1 or 2s internal hardware has "broke" which stops ECU 1 sending this data or ECU 2 receiving this data.
However without knowing if thats how the system is supposed to work it's just pure guesswork from me and I could very well be (and am likely to be) utterly wrong :D
Anyway, thats enough for me, the cars being picked up in a few days and when/if MRC find the issue I'll report back.
IanH755
Post by IanH755 » Sun Jul 20, 2025 1:09 am
It's back and with a very simple fix, yet still lived upto its name as the £1000 car because anything happens at all and it usually starts at £1000 to fix it!
So, after suspecting fuel it turns out there's nothing wrong with the fuel system. I got help from another RS6 owner on the RS Forum who checked their fuelling readings on VCDS and they're the same as mine, so my initial thoughts about ECU 2 and fuel were wrong. Instead, knowing that it can't be fuel, I started to look the other way (as I had Fuel and Air) and went for spark instead and checked the fuses which deal with ECUs, only it seems I didn't check well enough because, within a few hours at MRC they confirmed that the Coil-packs weren't powered, and that the fuse which controls them (SA2) had blown.
Now, not to throw the internet and Audi under the bus here, but both online AND in the owners manual, there is NOTHING mentioned about there being a set of fuses hidden inside the engine bay of my car, so that my excuse for not checking these particular ones as I never knew they existed. Also,the wiring diagrams labelling scheme for fuses is a little chaotic as the names/numbers used in the diagrams don't match what the manual/online/car etc actually names them - however I really still should have picked up on a simple blown fuse and the ELSAWIN wiring diagrams are fairly clear if you delve deeply enough, so maybe, just maybe, there's juuuuuust a tiny bit of blame attached to me too, maybe biggrin
Anyway, now on to the really weird part of all this - why did the fuse blow - it turns out that the Fuse, which should be a an absolute minimum of 15A rating as a minimum depending on car spec (the wiring diagrams show its 30A for an RS6) actually only had a 10A fuse fitted, and we can't see why anyone would do that. MRC replaced the fuse with the correct rating and dyno'd the car a few times to see if the fault will replicate, it didn't and the car behaved well on the dyno, considering the ambient temps today at 28'c+.
Its all back home now, all working again and being monitored with a few spare fuses on standby just in case. So with a £500 bill to low-load the car, the £100+ on the several taxis, trains, tube stops etc, all to get from my home to Banbury, £85 of fuel in the car after the return home etc, plus MRC's Labour and some dyno time to prove it won't pop again etc at the speeds it happened at originally, and we're at £1000 again, all for a <£1 fuse!
Yay!
Post by Ian_C » Tue Jul 29, 2025 4:49 pm
What a pain in the arse. Glad both yourself and 6 survived all okay. 8)
Return to “Readers' Rides”
Users browsing this forum: No registered users and 7 guests
