IanH's C6 RS6 - 925hp & 1150nm - Updated 06 Jun '25
neilparf
Re: My 900+ spec
Post by neilparf » Tue May 03, 2016 9:13 pm
Ian - wow. Simply, wow.
Just add the ceramics and this Death Star is complete!
Awesome work.
Gone but never forgotten:
TomRS
Re: My 900+ spec
Post by TomRS » Thu May 05, 2016 11:25 am
neilparf wrote:Ian - wow. Simply, wow.
Awesome work.
Think he's going to run the same setup as i am 410mm Steels... as without going into way loads of detail the Audi Ceramic compound is no good for track use.
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten :smile_smoking:
2010 Nissan GT-R SVM 680R
Shinobi675
Re: My 900+ spec
Post by Shinobi675 » Thu May 05, 2016 8:10 pm
I'm so happy you boys are around :) the laws of physics argument about ceramics always annoyed me.
Tyre grip is the limiting factor so steals can clearly stop as powerfully as ceramics... The weight is the benefit. Bit that 410 setup is pretty light unsprung weoghtx
rtd
Re: My 900+ spec
Post by rtd » Thu May 05, 2016 8:47 pm
The issue is in what conditions each application is used. There are pros and cons for both material types.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
IanH755
Re: My 900+ spec
Post by IanH755 » Thu May 05, 2016 10:11 pm
Absolutely true there Gurj!
To prevent derailing the thread into a brake debate I'd suggest a separate "Audi OEM Ceramics vs Steel" thread be made.
TomRS
Re: My 900+ spec
Post by TomRS » Fri May 06, 2016 9:20 am
IanH755 wrote:Absolutely true there Gurj!
Create one? its about time we put this to bed ;)
IanH755
Re: My 900+ spec
Post by IanH755 » Sun May 08, 2016 9:51 am
If anyone is interested in my history with the C6 I've kept a "Car Diary" over on Pistonheads with everything I've done since the day I bought her and it'll be kept up to date with constant updates - http://www.pistonheads.com/gassing/topi ... &t=1530059
leehewitt
Re: My 900+ spec
Post by leehewitt » Sun May 08, 2016 10:35 am
Ian - hats off to you Buddy - 750 aint cutting for me anymore...im off to rob a bank coz I need some of that!!!
One question re water meth - did you install this at stage 2 or after - any noticeable improvements as that's my realistic short term upgrade ? living In Dubai I see this as a no brainer..
Thanks in advance Lee
Daytona Loon - Stage 2 + - No F/R Cats - 3" MTM Valved Zorst - AP F&R Discs DS2500 Pads - Kw v3 Coilover - 10mm Spacers - TRUPS LED etc...
IanH755
Re: My 900+ spec
Post by IanH755 » Sun May 08, 2016 2:52 pm
It was part of the stage 3 upgrade so I've no idea what it'd be like for stage 2 I'm afraid.
classba
Re: My 900+ spec
Post by classba » Sun May 08, 2016 2:57 pm
Water meth for stage 2 give you the edge only if you map it in. I had it when I had stage 2 but not mapped in. Just the advantage of running cooler without additional power was good enough for me. With hybrids, it is a different story and is a MUST because you are fighting with massive heat soaks especially if you are running OEM or not so efficient intercoolers.
leehewitt
Re: My 900+ spec
Post by leehewitt » Sun May 08, 2016 7:52 pm
Thanks Ian / Classba I'm going to map it in so will hopefully feel the benefit plus it will make me feel better with outside temps in the high 40s over the coming months...
Re: My 900+ spec
Post by HYFR » Mon May 09, 2016 11:11 am
900PS + 2tonnes with steel brakes is not somewhere I would want to be...
classba
Re: My 900+ spec
Post by classba » Mon May 09, 2016 12:56 pm
HYFR wrote:900PS + 2tonnes with steel brakes is not somewhere I would want to be...
+1 Here we go again lol :)
classba
Re: My 900+ spec
Post by classba » Mon May 09, 2016 1:22 pm
IanH755 wrote:If anyone is interested in my history with the C6 I've kept a "Car Diary" over on Pistonheads with everything I've done since the day I bought her and it'll be kept up to date with constant updates - http://www.pistonheads.com/gassing/topi ... &t=1530059
This man loves to write lol :)
rtd
Re: My 900+ spec
Post by rtd » Mon May 09, 2016 6:14 pm
Yep he does so - but is respected and appreciated by many users who value his opinion and honesty in what he says and does.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
Return to “Readers' Rides”
Users browsing this forum: No registered users and 3 guests
