3 bar MAF
Posted: Tue Sep 07, 2004 10:31 am
by lskov
Does the ADU engine have a 3 bar MAF?
It seems that I cant get any more pressure than app. 1.5-1.6 bar now.
When I adjust the pressure to more than that the engine starts to run badly.... (I have upgraded exhaust, turbo etc....)
Posted: Tue Sep 07, 2004 7:45 pm
by Greg_S
have you had car remapped for new ignition timing and fuelling? if not the ECU can only compensate so much before things start going wrong.
Greg
Posted: Wed Sep 08, 2004 8:09 am
by Jani
Yes it does have 3bar pressure sensor.
Don't know how you've upgraded the Motronic maps, would suspect the same as Greg, it runs out of fuel & ignition maps
Posted: Sun Nov 07, 2004 12:36 am
by s2driver
MAF is Mass Air Flow sensor.....this doesn't have a pressure rating as it measures air speed which the ECU can determine as mass flow rate.
An RS2 has, as standard a 3 bar MAP sensor (Manifold Absolute Pressure). This is absolute pressure so can measure up to 2 bar above nominal atmospheric pressure (well theres an altitude sensor for further compensation inside the left hand A pillar).
Stock ABY S2 is 2.5bar MAP sensor and the 3B S2 has only a 2bar one.
Isklov, are you using a manual boost controller by any chance? This is not good on an S2 or RS2...be very careful. And you've upgrade turbo and exhaust too? You need a custom remap to take advantages of these changes to keep things safe/reliable and to maximise performance/economy.
