Sorry guys if I rehashing an old topic, but I did have a good dif around honest! A pair of Porsche Cup 1 alloys has popped up on EBAY. What I need to know is will they fit on the RS2 with no modification? I thinking about getting a second set for winter tyres of for some track day action if I'm feeling brave.
http://cgi.ebay.co.uk/Porsche-OEM-Cup1- ... 3caef6db91
cheers
MMM
Do Regular porsche Cup 1 alloys fit the RS ?
RE: Do Regular porsche Cup 1 alloys fit the RS ?
NO they don't. only thing stopping them fitting is the centre bore. Porsche is 71.6 RS2 is 73.1
Just take them to a machine shop and get them to turn them out.
HTH
HTH
those have the wrong off set too!
Thanks for that. What should the offset be. I must admit to being a bit confused by this stuff
The 7" standard wheel has a 55 off set if you went higher say 60 the wheel moves inwards.
You have to take into account wheel width. If you went to 8" wide the extra 1" is added to both sides of the center line.
The 964 did come with 8" wide et52. They fit spot on after the middle has been turned out. You can then run the 245 40 17.
HTH
HTH
Right I will see if I can hunt down a set of those. I take it that extra width doesn't hit the arches (just had them rubbed down, treated and resprayed to get rid of some rot) or the inner wings.
Thanks for the help
MMM
Thanks for the help
MMM
Users browsing this forum: No registered users and 149 guests
