Santa Pod RWYB Sunday 20th May
I used one when I went down the runway (0-160 vid clip) and it worked fine... problem is the seats, rearview mirror etc get in the way and the mount I used didnt work so well with the sunroof either... but different mounts be different I suppose.
I wouldnt mind doing this... I could give it a try I guess? But in the moment you are sooo hyped up that remembering to get everything together in time is a bit tricky. Ideally a passenger needed but that wont help times. It does not have to be a all out best time attempt I guess, be good to compare pod time vs. VAG-0Com time and see how accurate it is.
I'll have a go at this, and a fixed video camera on the dash, facing back etc. as well.
With the vag-com, you just need to press go when you are staged and it starts measuring when you move.
Do they allow passengers ?
I'm not sure how many runs we can get if it's busy.
Seen the weather forecast
average I guess. http://uk.weather.com/weather/local/NN2 ... 2=7xa&y=11
No passengers at Santa Pod. There is a good FAQ etc here: http://www.rwyb.co.uk/
Nice write up on the staging (lights) process and what you are meant to do. Basically once green you go when you are ready.
Weather looking bright for Sunday by BBC, but too soon to tell: http://www.bbc.co.uk/weather/5day.shtml?id=2846
Now it's been a while since I have been so this is a suggestion, but it worked for the group the few times I have been. Some of us are spectating only and we are arriving at different times but I suggest everyone enters the venue as shown, not stopping at the car park. It will be much nicer if we can try and get parked up together. On a regular RWYB day this is highly likely to be possible.
The picture looks like it was from a busy event - marquees etc up everywhere. It wont be like that. The blue cross I have marked I think is the greasy spoon cafe on site. If we at least all park around this side of the venue, hopefully we will be able to group together when not in the queue for runs.
- Attachments
- SantaPod2.jpg (210.59 KiB) Viewed 1615 times
Present: 2010 Ice silver B8 S4 s-tronic saloon (standard)
Past: 1998 Agate grey B5 S4 saloon (MRC tuned)
Hers: 2011 Volcano red 8P A3 Sportback 2.0 TDI 170 sport quattro
They dont usually operate the main carparks for RWYB events so you should be able to drive Straight round. There is plenty of parking area at the cafe/pits side of the track. The area at the bottom of the pic where cars are parked is all tarmaced now.
See you all there.
Make sure you all take your licences with you
I'm not sure if I'll be running my car, my mate Toby will be racing his Caddy so I might stick to video duty but then I suspect I'll get bullied into racing at some point during the day
See you all there.
Quattro Rocket Science
My car won't be ready for this so I'm moving myself from the running to spectating listGrahamS4 wrote:GrahamS4, Spectating
RSVI (Trying to butter the missus up and get permission)
ScottyBoy, Spectating
Ads4, Spectating (although could be tempted on the day!).
GrimReaper, Spectating
S4TAN, Spectating ...
SimonS4MTM, spectating (hangover status dependant)
Peakz, Spectating
MarkB, Running
Zerok66, Running
S4woody Running
Nickb, Running
DavidT, Running
Doug_S2 Running
Peakz, Spectating
MarkB, Spectating
Zerok66, Running
S4woody Running
Nickb, Running
DavidT, Running
Doug_S2 Running
Mark
I'll be there too but just spectating I expect.
Peakz, Spectating
MarkB, Spectating
Daz, Spectating
Zerok66, Running
S4woody Running
Nickb, Running
DavidT, Running
Doug_S2 Running
Peakz, Spectating
MarkB, Spectating
Daz, Spectating
Zerok66, Running
S4woody Running
Nickb, Running
DavidT, Running
Doug_S2 Running
Cheers,
Daz
Audi RS4 Cabriolet with added Milltek - Gone
Daz
I've also popped over from TSN, I'll be running with Az!
Peakz, Spectating
MarkB, Spectating
Daz, Spectating
Zerok66, Running
S4woody Running
Nickb, Running
DavidT, Running
Doug_S2 Running
Azure (TSN) Running
Stevie_d (TSN) Running
Peakz, Spectating
MarkB, Spectating
Daz, Spectating
Zerok66, Running
S4woody Running
Nickb, Running
DavidT, Running
Doug_S2 Running
Azure (TSN) Running
I planned to get my exhaust and intercoolers sorted before this but waited a month for some parts from Demon Tweeks. Nothing fancy, just some pipe and fastenings. I've canceled the order nowAds4 wrote:What have you done this time Mark????My car won't be ready for this so I'm moving myself from the running to spectating list I probably won't even be coming in the Audi
Mark
