Oil Cooler Return Line Leaking - Options?
Posted: Mon Feb 01, 2010 12:36 am
Over the last couple of weeks I could smell a feint whiff of oil in the cabin. I don't drive the car that often during the week and as it's been wet and cold I thought nothing of investigating until today… originally planned the day to replace the front pads!
Doh! - wish I had checked sooner, the whole undertray was covered in oil and nearside arch and wheel was splattered and cacked as well! – Oil wasn’t registering even on the dipstick – thankfully I haven’t driven far since I first smelt the problem.
Many frustrations later (too cold to be doing this kind of job outside) I discovered the cause of the leak. - The oil cooler return line appears to have either corroded or had a stone chip damage the line near where the plastic fog light cover is on the near side.
When I eventually cleaned off the mess I traced the smallest of pin prick holes that when under pressure was spraying like a geyser!
It was hard enough removing the bumper to do a temporary repair, quite proud of myself though I managed to clean the rust and gunk off the line and using an off cut of rubber pipe and some heavy duty jubilee clips I made a sort of pressure bandage that appears to have done the trick or at least stemmed the flow to not render the car useless. – Filled her up with only a litre so wasn’t as empty as had initially thought.
This looks like a complete b1tch of a job to replace, so has anyone suffered similar and gone an aftermarket route or got any tips to share for replacement?
In the attached from ETKA diagram it’s part 14 but it looks like it’s the wrong way round the bent end connects to the cooler and that’s where the hole is.
Any help gratefully received.
Guy
Guy
