Fuel filter replacement
Posted: Wed Oct 14, 2009 2:40 am
by roi354
Can someone point me to a guide to changing the fuel filter on the B5 RS4 as it looks to me like you need to drop the subframe and tank??!!??!!??
The bolt is spinning in the plastic bracket and I don't really want to cut it and cable tie the new one on
Cheers,
Rob
RE: Fuel filter replacement
Posted: Wed Oct 14, 2009 3:38 am
by quattrokid1
all you need to do is have the fuel tank as empty as you can get it, then release the holding straps then remove the fuel filter. no need to drop the sub frame. I've watched Grizz and Lee at Unit 20 do ours and it took about half an hour to do.
contact Grizz if your not sure.
(google Unit 20) he is in Chester
Posted: Wed Oct 14, 2009 3:53 pm
by roi354
Ahh that sounds ok, with a quick look it seemed really unnecessarily difficult so I knew there would be a simpler way.
Re: RE: Fuel filter replacement
Posted: Wed Oct 14, 2009 5:01 pm
by ollys
roi354 wrote:Ahh that sounds ok, with a quick look it seemed really unnecessarily difficult so I knew there would be a simpler way.
don't ask Audi to do this - they wanted to charge 7 - 10 hours labour!!!
RE: Re: RE: Fuel filter replacement
Posted: Wed Oct 14, 2009 6:02 pm
by eyeball
and thats just for the removal...lol
Posted: Wed Oct 14, 2009 6:06 pm
by mikeyquattro
It's a pita. Get the professionals to do it (MRC, Grizz etc...)
Posted: Wed Oct 14, 2009 6:21 pm
by Virdee Autos
A few cars have the nut spinning.
Get a helping hand, and prise the bracket slightly with a flat blade screwdriver, and then with the second pair of hands, open as usual. You should be able to loosen it, and replace the filter as per normal.
As said just drop the tank slightly, and make sure you use new washers.
Posted: Thu Oct 15, 2009 4:38 am
by roi354
Thanks, will let you know how much stuff I throw across the workshop after next week
Posted: Thu Oct 15, 2009 4:06 pm
by Mr V10
Heres a write up on when I changed the fuel filter on my old A8. Not sure if its the same as the RS 4 but I'm guessing it could be simlair
http://forum.a8parts.co.uk/showthread.php?t=128
Posted: Thu Oct 15, 2009 7:27 pm
by DutchRS4
