Page 1 of 3
Maintaining an RS4, what next?
Posted: Mon Jun 30, 2008 6:58 am
by A20LEE
Recently bought my first RS4 and in the process of getting it spot on. Its got 83k on it and had the cambelt service at 79k. I've had an interval service done at 82k when i bought the car.
So far i've replaced the DV's with 710N's and replaced the MAF. I'll do the N75 and afterrun mod in the next couple of weeks too. What else should i be doing? Diff oil? N249? I'm new to RS and quattro (torsen) so still finding my feet and want to make sure i'm covering everything as i'm sure there will be stuff that gets missed by dealers but common knowledge to everyone one on here.
TIA
RE: Maintaining an RS4, what next?
Posted: Mon Jun 30, 2008 9:06 am
by neckarsulm
Have you VAG COM'd your car?
You really need to do this for peace of mind - I had a fault with a lambda sensor which didn't put the Check Engine light on but I replaced it anyway as it kept on coming back.
Also check to see if the existing coolant temp sensor is black or green - if it's black it's original and is probably faulty.
Was the thermostat done at the cambelt change as this caught me out recently.
Posted: Mon Jun 30, 2008 9:37 am
by jimbo1234567
pre cats
Re: RE: Maintaining an RS4, what next?
Posted: Mon Jun 30, 2008 10:01 am
by A20LEE
neckarsulm wrote:Have you VAG COM'd your car?
Car should have been VAG COM'd at Awesome when it was serviced but they missed the split DV's so i'll get it checked again just in case. I'll definately look at the coolant sensor. Where is it located? Not sure about the thermostate as the cambelt service was done by the previous owner.
Pre-Cats, all in good time. Want to make sure the car is spot on before the essential trip to MRC.
RE: Re: RE: Maintaining an RS4, what next?
Posted: Mon Jun 30, 2008 10:44 am
by Nige_RS4
Pressure test for small leaks is a must too! Also consider the turbo after-run pump mod.
Posted: Mon Jun 30, 2008 2:22 pm
by neckarsulm
Pressure test is good idea as Nige says.
I bet Awesome don't see many 2.7T cars so I can see why they missed the DVs, they wont cause a fault in VAG COM though I think if you know you way around VAG COM you can monitor boost levels and see if the DVs are shot that way- or just replace them if they aren't 710Ns as chances are they are shot.
I'd get your wheels checked for trueness too, easiest way is a wheel balancing machine, it really is easy to damage them.
Re: RE: Re: RE: Maintaining an RS4, what next?
Posted: Mon Jun 30, 2008 5:42 pm
by A20LEE
neckarsulm wrote:Pressure test is good idea as Nige says.
Anyone know of a company in Yorkshire that can pressure test it for me? Maybe right about Awesome as they didn't manage to fix the leaking cam cover it was booked in for either so probably not clued up on pressure testing 2.7T's. Think the wheels are actually new as there mint inside and out.
Then does the diff/gearbox require maintaince as my S3 need a Haldex service at 60K. Guess the RS4 would also require something similar.
RE: Re: RE: Re: RE: Maintaining an RS4, what next?
Posted: Mon Jun 30, 2008 5:44 pm
by flashyg
ill pressure test it if you bring it over on a sat and do a full vag analyses!
Re: RE: Re: RE: Re: RE: Maintaining an RS4, what next?
Posted: Mon Jun 30, 2008 5:55 pm
by A20LEE
flashyg wrote:ill pressure test it if you bring it over on a sat and do a full vag analyses!
Nice one, PM on the way.
RE: Re: RE: Re: RE: Re: RE: Maintaining an RS4, what next?
Posted: Mon Jun 30, 2008 6:31 pm
by quattrokid1
OH... i'll be in Leeds as well Saturday if you fancy a meet up?
Bramley end of town I think.. yep thats what its called
by jimbo1234567
get yourself to the next nw meeting lee so we can all kick your tyres
Re: RE: Re: RE: Re: RE: Re: RE: Maintaining an RS4, what nex
Posted: Mon Jun 30, 2008 7:21 pm
by A20LEE
quattrokid1 wrote:OH... i'll be in Leeds as well Saturday if you fancy a meet up?
I'm in Pudsey, about 4min drive from Bramley. Think a mini meet would be ace. I'll see if my mate Tim wants to bring his RS4 B5 over too. Interested in a pressure test too? Flashy is manchester way but if we chip in for his traveling costs maybe we could twist his arm into have a look at a couple, possibly three cars?
Flashy, i've got three compressors! No problem with you rate, half want my local specialist would charge.
RE: Re: RE: Re: RE: Re: RE: Re: RE: Maintaining an RS4, what
Posted: Mon Jun 30, 2008 9:02 pm
by quattrokid1
who is gonna chip in for me then coming down from Scotland
yea that sounds like a great idea.
action phot... action phot!! camera at 5 mins notice
Posted: Mon Jun 30, 2008 11:32 pm
by imolas4uk
no haldex coupling on an rs4,just change the rear axle oil and gearbox oil,no interval is specified by audi so it wil never have been done unless is had repairs to those items.
Posted: Tue Jul 01, 2008 9:37 am
by mbelle
I'd be up for a mini meet in Leeds - missus wants to see some friends over there anyway!
