Quattro GMBH rear discs
Posted: Fri Jun 13, 2008 8:05 pm
by shaky
Anyone have a contact of where to source these from??
Prices too would be appreciated
Thanks Rick
RE: Quattro GMBH rear discs
Posted: Sat Jun 14, 2008 5:54 am
by boxerdogted
You will need a chassis number from a car that had them fitted from new, Audi wont order them without this.
There are a few posts about this (do a search), as for price be prepared for a shock when i enquired they quoted me approx £800 a pair.
I have just fitted a complete B7 RS4 rear setup for the same money.
Gareth.
Posted: Sat Jun 14, 2008 7:13 am
by shaky
Thats another option I suppose, were they a simple fit or a bit of a pain??
Any pics?
Posted: Sat Jun 14, 2008 10:54 am
by boxerdogted
Posted: Mon Jun 16, 2008 7:47 am
by shaky
I've read brooner's guide, which is very helpful - i'm not sure about the scalloping of the rear hub though did you manage to get around this??
Posted: Mon Jun 16, 2008 11:41 am
by wozza
I've got the Quattro gmbh rears on mine - got em from Kim Collins @ QSTuning.. bout 550 or something I'll dig out the invoice and let you know or give em a call..
http://www.qstuning.com/
I looked at the various options but personally didn't want to modify the car and want to be able to set back to original if I felt like it. Spoke to Doug at MRC about machining up some bits rather than drill out the rear mounts so we could fit the B7 setup on it - but didn't get anywhere and decided on the quattro discs.
Kim at QST said he gets em from MTM..
Posted: Mon Jun 16, 2008 10:09 pm
by wozza
Invoice was £500 ex vat, £12 delivery £601.60 all up.. (as of 14 sept last year)
Posted: Tue Jun 17, 2008 6:51 am
by shaky
Thanks wozza, at least now I can weigh up the pro's and con's of both setups!
Posted: Tue Jun 17, 2008 6:54 am
by boxerdogted
The scollop in the rear hub only has to go 1mm deep so not a problem and took about 5mins with a dremmel.
You should be carefull that you square the drill up when drilling the holes to keep them acurate. The only other slight mod that is required is trim the backplate by approx 8mm each side to clear the larger caliper.
HTH
Gareth.
Posted: Tue Jun 17, 2008 8:36 am
by blackb1ade
What Wozza said - I went *exactly* the same route
Posted: Thu Jun 19, 2008 9:50 am
by rsmonkey918
Had the rear B7 upgrade about 6 weeks ago at MRC without any drilling/scalloping etc- just the right diameter/length allen bolt inserted from INBOARD with a nut and spacer washer to keep the disc centred up when it gets hot- apparently they can 'drag' otherwise. Top job, no mods to hub= happy camper!
looking for the same thing, my rears are toast
Posted: Thu Jun 19, 2008 11:28 pm
by trichards
thx
